Run flows in succession
If you want a flow to run immediately after another flow is complete, open the flow that you want to trigger the next flow and click the Settings ( ) button in the upper right corner. From the Settings panel, select the flow you want to run next from the Next integration flow drop-down menu.
Related links
- NetSuite Concurrency Governance
- Email Notifications on Flows and Connectors
- User Management and Account Ownership Transfer
Take the Advanced Flow Builder class to learn more about this topic.
