Transformations 2.0: Field settings
This article describes the output field settings available in Transformations 2.0. Use it as a reference when configuring how source data is restructured and mapped to output fields in a transformation.
Output field settings
Select Settings (settings_gear.svg​) to the right of the output field to configure additional settings.
Output data type: displays the selected data type for the output field you are mapping. Select a different value to change the data type. If you get an error message, you can attempt to validate your data type.
Output types: Select the type of field you want to apply to the output record. The types available change depending on the data type you select.
The following field transformation types are available for each data type.
Output data type Field output types
string
number
Boolean
[string]
[number]
[Boolean]
object
[object]
  • Copy an object array as-is from input data
  • Create an object array in transformation
  • Hard-coded
  • Handlebars expression (extract only — child mappings use JSONPath)
Standard
Send the value of the input field as the value in the output field. This is the default setting, indicating that data found in a specific field in the export should map to its corollary in the import application (1:1 direct mapping).
Hard-coded
Set the source field to a defined value for the destination field. Use this setting if you prefer to have the same value written to this imported data field for every record, regardless of the exported value.
How would you like to hard-code the value?: Select one of the following options:
  • Use custom default value: Inserts custom string value
  • Use empty string as default value: Inserts empty string
  • Use null as default value: Inserts null value
Custom value: Enter the value to send to the destination field. This field only displays if you choose Use custom default value from How would you like to hard-code the value?.
Hard-coded values are supported for object and [object] (object array) output types, in addition to primitive types. Enter the static object or array-of-objects value directly in the output field. Transformations 2.0 validates the entered value and shows a preview so you can confirm the structure before saving. This applies across exports, lookups, and imports.
Keep the following behavior in mind when hard-coding object and object array values:
  • An empty string resolves to an empty object {} for object fields, or an empty array [] for [object] fields. A null value is passed through as null for either type — it isn't converted to {} or [].
  • If a [object] field's hard-coded value is a single JSON object rather than an array (for example, {"id": 1, "label": "Primary"} instead of [{"id": 1, "label": "Primary"}]), Transformation 2.0 automatically wraps it into a one-element array.
  • Hard-coded can't be combined with another mapping approach on the same field. For object fields, this means you can't set both hard-coded and copy-as-is (or a field-by-field mapping). For [object] fields, hard-coded can't be combined with the array-building helper used to construct array items from input data. Saving a field with both configured is rejected.
Object and object array output fields support three approaches: copying the value as-is from input data, using a Handlebars expression for computed values, and hard-coding static values that don't vary between records. Choose hard-coded when the output value is fixed regardless of the input record.
Build a handlebars expression for the value in the input field to send to the output field. Handlebars expressions are supported for string, number, Boolean, [string], [number], [Boolean], object, and [object] output field types.
  • For object fields, handlebars is supported in copy-as-is mode only.
  • For [object] fields, handlebars applies at the helper extract level only — child field mappings within the array continue to use JSONPath.
  • For [string], [number], and [Boolean] fields, handlebars-returned arrays are used directly and are not comma-split, unlike plain-text values.
Handlebars expression: Enter a simple handlebars expression in the field, or select (pencil_handlebars.svg) to open the Handlebars advanced field editor (AFE).
Action to take if handlebars expression returns an empty value: Select what Transformations 2.0 should do when the expression returns an empty value:
  • Do nothing (default): The field name and value is skipped.
  • Use custom default value: Inserts any string value you enter in the field provided.
  • Use empty string as default value: Inserts empty string.
  • Use null as default value: Inserts null value.
Lookup
Use a static lookup or lookup cache to replace specific field values from the input data before they are sent to the output application.
Static lookup
For each Input field value, define the corresponding replacement Output field value that will be sent to the destination application.
Output field value: Enter the value as it would be replaced when sent to the output application.
Input field: The input field name.
Input field value: Enter the corresponding value that this field uses in the input data. You can also use {{handlebars}} expressions and add multiple values separated by commas.
An additional empty line is added to the list with each new value you add, and you can select Delete (trash.svg) on the right to delete any line.
Lookup name: Give the lookup a unique name so that it can be easily identified for use in other flows. You can also select any static lookups used in other flows.
If lookup fails: If no match returns from the lookup search, the record fails by default. integrator.io marks the record as failed and does not transfer any data for that record. You can select one of the following alternative options if needed:
  • Do nothing: The field and value is skipped.
  • Fail record (default): integrator.io marks the record as failed and does not transfer any data for that record.
  • Use custom default value: Inserts custom string value.
Lookup cache
If you're using a lookup cache to define the mapping, enter values for the following fields:
Lookup cache name: Enter a part of the name or the full name to search and find an existing cache. If you want to create a new cache, provide a unique and meaningful name.
Lookup cache value field: Select a field path (provided in JSON notation) to map the destination data. With the lookup cache key as a reference, this path value is a unique identifier to map the data.
Output field is date field
Check this box if the output field requires a date format. Additional date field options display if this box is checked.
Date field options
Input field date format: Select the date format for the input field.
Input field date time zone: Select the time zone for the input field.
Output field date format: Select the date format for the output field.
Output field date time zone: Select the time zone for the output field.
Input field and Input data type
Input field: This field is automatically set if you have already mapped an input field in the Transformations 2.0 panel. If you are adding a new field, you must also assign the Source data type.
Input data type: If you have already selected an Input field, the data type is automatically set. If you added a new input field, use the drop-down list to set its data type.
Action to take if input record field has no value
Select one of the following options to control what Transformations 2.0 does when the input record field has no value. The options available vary by data type.
Data type Action to take if source record field has no value Transformations 2.0
string Use empty string as default value Inserts empty string
Use null as default value Inserts null value
Use custom default value Inserts custom string value
Do nothing (default) Removes field name and value
Cause record to fail Causes record to fail
number Use empty string as default value Inserts 0
Use custom default value Inserts custom number value
Boolean Use empty string as default value N/A
Use null as default value Inserts false
Use custom default value Selects true or false
object Use null as default value Inserts null value without object formatting
[string] Use empty string as default value Inserts empty array
Use null as default value Inserts null value without array formatting
Use custom default value Inserts custom values as array ["a", "b", "c", "d"]
[number] Use empty string as default value Inserts empty array
Use custom default value Inserts custom number values as an array [1, 2, 3, 4]
[Boolean] Use empty string as default value Inserts empty array
Use custom default value Inserts custom values as an array [true, false, false]
[object] Use null as default value Inserts null value without object formatting
Settings description: Enter an optional description of the settings configured for this field.
