Create an application
An application is what you use to subscribe to and consume an API. This article is for API consumers; if you're a publisher looking to create and publish APIs instead, see the Secure your API section. Before you start, it helps to understand plans, applications, and subscriptions. After creating your application, subscribe it to an API.
You'll do this from the Developer Portal. If you don't have access to it, contact your API publisher.
  1. Navigate to Applications > Create an app, or select Create Application from the Dashboard.
  2. Enter a Name (required).
  3. Optionally, enter a Description and a Domain — for example, https://<my-application>.com/.
  4. Select a Type. Which types are available depends on what your publisher has configured: Simple (a hands-free type where you define the client ID yourself), Browser (Angular, React, and similar), Web (Java, .NET, and similar), Native (iOS, Android, and similar), or Backend-to-Backend.
  5. Enter a client ID if your application type requires one. If you're not sure, leave it blank — the system prompts you for one when it's needed to subscribe to a plan.
  6. Optionally, search for and add the APIs you want and select a tier for each. You can also leave this blank and subscribe later.
  7. Review your details and select Create.
Delete an application
Open the application from the Dashboard or the Applications list, select Remove on the General tab, and confirm.
Add or remove members
Only the application's creator (its primary owner) can see and manage it at first. To add or remove members:
  1. Sign in to the Developer Portal.
  2. Select Applications in the top menu.
  3. Select your application, then open the Members page.
  4. Search for the user you want to add, assign a role, and select Add.
  5. To remove a member, select the trash icon next to their name.
