Assign errors
Assigning errors in lets you delegate troubleshooting to specific team members so issues get resolved quickly.
Tip: Combine assignment with tags to organize errors into a searchable, prioritized backlog that keeps critical blockers visible.
Error assignment permissions
The following table defines which roles can perform assignment and invitation actions:
Action Who can do it Requirement
Invite users Owners or Admins None
Invite users Non-admins Invitations must be turned on in account settings.
Assign errors All users Requires Monitor access or higher.
Assign to new users Non-admins Invitations must be turned on in account settings.
Invitation methods for error assignment
If a colleague is not currently a user in the integration, use one of the following methods to add them:
  • Simultaneous assignment: In the Errors list, select your errors and enter the new user's email. The system sends an invitation and the error notification at the same time.
  • Manual invitation: Add the user via the Users tab before assigning errors.
    • Navigation: Integration > Users > Invite user
Assign errors to a user
Follow these steps to delegate one or more open errors:
  1. Go to the Open errors list for the specific flow step.
  2. Select the checkbox for the errors you want to delegate.
  3. Choose an assignment option:
    • Single error: Select Assign errors in the specific row.
    • Multiple errors: Select the checkbox next to the errors and then select Assign errors at the top of the list.
  4. Select a name from the list or enter a new email address in the Assign to new user field.
  5. Select Assign.
To remove an assignment, select the assignee's name and select Clear assignment.
Automated notification when errors are assigned
The platform manages notifications to ensure users stay informed without receiving excessive emails:
  • Wait period: The platform waits 15 minutes after the first assignment before sending an email. Any other errors assigned to that user during this window are bundled into one notification.
  • Batch limit: Each email contains a maximum of 25 errors.
  • Acceptance: New users must accept their invitation and sign in before they can view assigned errors.
Self-assignment: The platform does not send notifications if you assign an error to yourself.
Error notifications vs Error assignment notifications: Error notifications in an integration are sent only when you or your account owner/admin configure them for specifc flows, but assignment notifications are automatically sent when an error is assigned.
Filter errors by assignee
You can filter the error list to manage specific workloads or track progress.
  1. In the Errors list, select the Filter icon.
  2. Select the checkbox for specific users or Tags.
  3. Select Apply.
Automatic assignment rules
The platform uses identifiers to automatically route recurring errors to the same user.
Identifier type Assignment behavior
Retry data key Automatically assigns all matching open errors to the same user.
Trace key Assigns new occurrences to the same user if the Auto-resolve errors with matching trace key option is turned on in flow settings.
