You can now monitor and manage your retry runs in the Retries tab on the Errors page or from Flow builder.
When you retry errors in a flow step, you will receive the message "Retrying errors" indicating that the operation is still in progress or "Retry completed" indicating that the operation is finished. You can view the Retry messages at the top in Flow builder and in the Errors page.
Flow builder
Errors page
When a retry run is completed, click the View Results link at the top, to switch from the Flow builder to the Errors page, or the other way around.
If retries were triggered for more than one error, then when all the retries are completed, you can select any specific step from the drop-down list at the top and view the results for that step.
You can also view the Run console or Run history in Flow builder to see how the retries were processed across the downstream steps or any details. Retry jobs are marked with a Retry tag. From Run history, you can also open the execution logs for a retry job to see record-level and step-level details for the retry.
View the following retry details in the Run history/console in Flow builder or in the flow/step errors page (Retries tab).
| Field | Description |
| Retry status |
The retry status can be either Completed or Canceled.
You can check the Open errors or Resolved errors tab for details. |
| Duration | The time taken for the retry to be completed. |
| Retry started | The time when a retry is started. The time format is based on your profile settings. |
| Retry completed | The time when a retry run is completed. The time format is based on your profile settings. |
| Success | The number of errors that have been successfully retried. |
| Ignored | The number of errors that are ignored. |
| Errors |
The number of open errors in a run. To resolve errors, see Errors API endpoints and Intro to Error Management. If a retry in one step triggers an error in the next step, then the number of errors is displayed in the next flow step. Entries in this column are not clickable. |
| Retry started by |
You can view retry runs started by any specific person. By default, the option is set to All users in the filter. Note that you will also find auto-retry runs here and, this field will contain Auto-retried for auto-retry runs. |
| Actions |
You can cancel any retry that is in progress. (Cancelling a retry will abort the retrying of any errors not yet processed; those errors already processed will not be reverted, maintaining their current state (failed or resolved).) |
You can cancel a retry of errors, only if a retry is in progress.
To cancel a retry run:
- Click the Retries tab.
- In the Actions column, click Cancel retry.
- Read the Confirm cancel retry message, and click Cancel retry.
In the Errors page, you can filter based on retries started by any user or auto-retries in your account. By default, All users is selected. The Run history also you to filter retries to examine any details.
