Auto-transform output fields using Celigo Ora
Auto-map allows you to use Celigo Ora prompts to populate source and destination field mappings. Auto-map applies to mappings that use string, number, boolean, array, object, object arrays, and input fields. You must have at least one row with a value in a destination field to auto-map with Celigo Ora.
  • This feature only applies to Transformation 2.0.
  • To auto-populate mappings, you must enable Celigo Ora in your integrator.io account. Click the avatar in the upper right corner of integrator.io, click Profile, and check the Enable Ora box.
Auto-transform all fields
You can auto-transform all input fields within the provided data using a prompt through Celigo Ora.
Before
Result
Celigo Ora prompt: I need to auto-transform all fields
Auto-transform doesn’t overwrite input field values that have already been entered manually. For example, if the input fields already have the values: studentName, and studentAge and you enter the prompt,  “I need to auto-transform all fields.” Auto-transform will preserve the manually entered fields and only add field mappings for the remaining input fields.
Before
Result
Auto-transform specific fields
For more targeted mapping, you can provide the exact names of one or more required fields in your prompt and auto-map only those fields. Use serial commas in plain English to separate each field name in your prompt.
Before
Result
Celigo Ora prompt: I need to auto transform studentName, studentAge, and grades
