The Pre save script is invoked before a resource is saved and is used to validate the submitted resource, perform any restriction and permission checks, and perform any last-minute changes to the current resource. A Pre save script can live on in the following resources: integration, flow, import, export, and connection. Whenever the resource is saved, it first goes through this script.
Warning
The Pre save script cannot be attached to a resource via the Celigo platform interface. To attach the script to a resource, you’ll need to use Postman or another third-party system and the Celigo integrator.io APIs.
* preSave function stub:
* The name of the function can be changed to anything you like.
* The function will be passed one 'options' argument that has the following fields:
* 'newResource' - the resource being saved.
* 'oldResource' - the resource last saved.
* 'sandbox' - boolean value indicating whether the script is invoked for sandbox.
* The function needs to return the newResource object to save.
* Throwing an exception will signal an error.
function preSave (options) {
return options.newResource;
In this example, the pre save script was used to set the value of a field map based on whether it was in a production or sandbox environment. Add it to a resource by adding this snippet to the root:
"preSave": {
"function": "yourScriptFunction",
"_scriptId": "yourScriptId"
Script example:
function preSave(options) {
options.newResource.settings = options.newResource.settings || {};
options.newResource.settings.sandbox = options.sandbox;
