As data moves from step to step in a flow, the record structure processed by any given step can change according to the transformations, scripts, and other changes that occured in previous steps. The sample input data displayed in Advanced field editors (AFEs) is the result of the last executed flow step (including scripts and transformations). However, this behavior was absent for some AFEs prior to the v8.2.1.0, February 2022 release.
The following table identifies the AFEs for which the v8.2.1.0, February 2022 release corrected the persistence of sample input data.
Flow step type |
Platform |
Advanced field editor (AFE) |
Export |
All platforms |
Data URI template |
Trace key template |
Import/Lookup |
All platforms |
PostMap Hook AFE editor |
PostSubmit Hook AFE editor |
MongoDB |
Filter |
Document |
Update |
Ignore lookup |
Filter |
DynamoDB |
Item document |
expression attribute values |
RDBMS Snowflake (bulk insert) |
Query Builder |
Existing Data ID Lookup |
Lookup Query builder |
HTTP REST |
Relative URI |
Body |
Lookup Relative URI |
Lookup Body |
AS2 |
File Name |
Message ID |
Body Template |
FTP |
File Name |
In Progress File Name |
Back Up Directory Path |
Directory Path |
Body Template |
S3 |
File Key |
Back Up Bucket |
Bucket |
Body Template |
Google Drive |
Relative URI |
Headers |
Back Up Path |
