Set up a connection to Aircall
Aircall is a cloud-based phone system designed to help businesses manage and optimize their communication and customer support operations.
Setting
Instructions
Name your connection *
Auth type *
Select your Aircall account authentication type (either Basic or OAuth 2.0).
API ID * (for basic authentication)
Enter your Aircall API ID (Username).
How to retrieve the API ID
API token *  (for basic authentication)
Enter your Aircall API token (Password).
Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API token
Client ID * (for OAuth 2.0 authentication)
Enter your Aircall client ID. To obtain the client ID, contact Aircall support.
Client secret * (for OAuth 2.0 authentication)
Enter your Aircall client secret. To obtain the client secret, contact Aircall support.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the respective Basic auth and OAuth 2.0 auth universal connector documentation.
How to retrieve the API ID and API token
  1. Sign in to your Aircall account.
  2. Navigate to Integrations and API > API keys.
  3. Click Generate an API key.
  4. Enter a Key name.
  5. Copy the API ID.
  6. Copy the API token.
  7. Click Confirm.
Additional references
