Celigo Private Cloud supports various secure connection methods, including Virtual Private Network (VPN) and IP whitelisting. This section provides guidelines for setting up and managing connectivity to your private instance.
VPN connectivity allows you to establish a secure, encrypted channel between your network and your Celigo Private Cloud dedicated instance. A VPN ensures secure transmission of sensitive data, limits access to your instance to authorized users and systems, and simplifies compliance with security and regulatory requirements.
IP whitelisting restricts access to your dedicated instance by defining a list of trusted IP addresses. Always use static IP addresses for systems that connect to your dedicated instance, and limit the number of IP addresses on the whitelist to reduce exposure.
Celigo Private Cloud supports seamless connections to cloud-hosted platforms such as Salesforce, NetSuite, or AWS-based services. Use API keys or OAuth for authentication when connecting to other systems, and verify that IP whitelisting or VPN access includes the required endpoints.
For on-premises systems that are hosted on your local network, Celigo Private Cloud can establish secure connectivity with VPN or other supported methods
Use Celigo’s built-in monitoring tools to track connectivity status and ensure uptime. You can set up alerts for connection failures, review access logs to monitor who is connecting to your dedicated instance (and when), and detect suspicious activity to ensure compliance with security policies. You should also periodically update VPN configurations, API tokens, and other credentials to maintain security.
Use Layered Security: Combine VPN, IP whitelisting, and single sign-on (SSO) for maximum security.
Plan for Redundancy: Implement backup connectivity options to ensure continuous access during outages or network disruptions.
Test Connections Regularly: Conduct routine tests to verify that all connectivity methods are functioning as expected.
For further assistance or troubleshooting, contact Celigo support.
