When you add a step to a flow, integrator.io looks for steps you've already built — in your other integrations and in Marketplace templates — that match the name and description you enter, and offers them so you don't configure the same export, import, lookup, tool, AI agent, or guardrail twice. This article explains how the suggestions work, what happens when you reuse a step, and what to consider before sharing one step between flows.
Find a matching step
- In Flow builder, select Add source or Add step, and then select the Application and Step type.
- In Name your flow step and Describe your flow step, enter a name and a description of up to 300 characters — keywords, an example, or the use case. integrator.io searches for similar steps using both.
- Under Optionally choose from pre-built flow steps, review the suggestions. Each shows a similarity score; a higher percentage is a closer match. Narrow the list with Source (All, My account, or Marketplace) and Connection, and order it with Sort by (Similarity score or Date modified).
- Select Use flow step on the step you want. Its name and description replace yours; you can edit them later. If nothing fits, select Next to build the step from scratch with the name and description you entered.
Steps from a Marketplace template that requires the publisher's approval don't appear until your account is approved; see Jump-start integrations with templates and apps.
What happens when you reuse a step
| Step comes from | Result |
| My account — an export, lookup, or import | The step keeps its connection, and integrator.io asks How would you like to use the existing flow step? Clone flow step (the default) makes an independent copy. Use same flow step puts the one existing step in this flow too, so a change to it in either flow affects both. |
| My account — a tool, AI agent, or guardrail | A tool step calls the existing tool. An AI agent or guardrail is copied under the same name; there's no option to use the same one. |
| Marketplace | The step is copied into your flow. A tool step calls the Marketplace tool itself. |
Before you share a step between flows
Connections, exports, imports, lookups, lookup caches, scripts, AI agents, guardrails, and async helpers are resources that any number of flows can use. Sharing saves setup, but a change to a shared resource changes every flow that uses it. When you open a shared resource, a Proceed with caution banner shows how many places use it; select Used by in the banner to see them before you save.
If several people build in your account, create a separate resource for each flow and give each one a name that says what it's for — a vague or duplicate name is how another flow's import gets edited by mistake.
