Run a flow
Run a flow on demand to test it before you schedule it, to catch up after a problem, or whenever you need records moved now. A flow has to be turned on before it can run; from there you can run all of its sources or only some, choose whether the flows that follow it run too, and for a delta flow, pick the date to start from. This article covers each of those. For running on a schedule, see Schedule a flow.
Turn a flow on and run it
  1. Go to Home home-icon.png, open the integration, and then select Flows.
  2. In the flow's row, turn on Enabled enable-flow.png. A flow that's off can't run, on demand or on a schedule.
  3. Select Run.
The run appears on the Dashboard; see Monitor flows on the Dashboard. In Flow builder, Run at the top right starts the same run. The Run console below the canvas lists every run of the flow — including runs started from the Dashboard or the API — with a row per step showing its status, duration, and success, ignored, and error counts, and lets you cancel a run that's in progress; see Cancel a flow run. The flow's Run history tab keeps the same runs for your data retention period, with filters by date and status; see View a flow's run history.
Turning a flow off stops its scheduled runs and disables Run; runs already in progress continue. To stop a run, see Cancel a flow run.
Run some of a flow's sources
When a flow has more than one source, Run in Flow builder opens Run this flow once:
  1. Select All sources, or select Selected sources and then Select sources to choose one or more.
  2. Select Start.
If the flow runs its sources in parallel (see Configure flow settings), Run additional sources lets you start the sources you left out while the first ones are still running.
Run the next flow, or not
If the flow's settings name a next flow, Run next flow(s) after current flow completes appears in the run dialog. Clear it to run this flow alone. Scheduled runs always run the next flow.
Backdate a delta flow
A delta export retrieves only the records that changed since the flow last ran. To retrieve older changes — after a flow was off, or to re-sync from a date — run the flow with an earlier start:
  1. In the flow's row, select Run. The Delta flow dialog opens.
  2. Select Custom.
  3. Select the Time zone, the Start date, and the Time.
  4. Select Run.
Only records changed after the start you choose are retrieved; changes before it are skipped. In integration apps, a backdated run doesn't create duplicate records.
Choose which source feeds the previews
In a flow with several sources, the previews in later steps show records from the first source by default. To preview with another source's records, point to that source, select Actions elipses-button.png, and then select Set as source for preview. The previews update immediately, whether the flow is in test mode or enabled. To check how each step handles your records before the flow goes to production, switch the toggle at the top of Flow builder from Enabled to Test mode and select Run test; see Debug a flow in test mode.
