Create a flow in Flow builder when you want to move records from one application to another automatically. You name the flow, choose the integration it belongs to, add a source step that retrieves records, and add a destination step that receives them; everything else — mapping, schedule, filters, extra steps — is added afterward. This article walks through creating the flow and its first two steps. To build a flow by describing it in plain language instead, ask Ora; see Celigo Ora overview.
Prerequisites: You must have Manage permissions for the integration; see Manage user roles & permissions to an account. You need at least one integration, because every flow belongs to one; see Create your first integration. Keep the API documentation for each application at hand — you'll need it to configure connections and steps.
Create the flow
- Go to Home
, and then select Create > Flow.
- Enter a Name and, optionally, a Description.
- Select the Integration the flow belongs to, or select Create new integration. Only integrations where you have Manage permissions are listed; if none are, ask your administrator for access.
- Optionally, select a Flow group.
- Select Create.
Flow builder opens with an empty Add source step and an empty Add step.
Add the source
- In Flow builder, select Add source.
- Select the Application to retrieve records from. If it isn't listed, use an HTTP connection; see Create a connection to an application.
- Select the Step type. The types available depend on the application:
- Export records from source application — retrieves records on the flow's schedule or on demand.
- Transfer files out of source application — retrieves files as-is, without parsing them.
- Listen for real-time data from source application — receives records the application pushes to a webhook URL.
- Select an existing Connection or select Create connection.
- Enter a name for the step in Name your flow step and, optionally, a description of up to 300 characters in Describe your flow step. integrator.io uses both to suggest matching steps you already have; see Reuse an existing flow step.
- Select Next, and then configure the step. The settings are specific to the application and step type; see the application's connector article. For a listener, see Create webhook listeners.
Add the destination
- In Flow builder, select Add step.
- Select the Application to send records to.
- Select the Step type:
- Import records into destination application — creates, updates, or deletes records in the application.
- Transfer files into destination application — sends files as-is.
- The Look up types add a lookup step rather than a destination; see Add lookup, transfer, and other steps to a flow.
- Name and describe the step, and then select Next.
- Configure the import. The settings are specific to the application; see the application's connector article.
Next steps
- Map the source fields to the destination fields: select Mapping
on the import step. See Mapper 2.0.
- Add lookups, more destinations, branching, or other steps; see Add lookup, transfer, and other steps to a flow.
- Filter, transform, or script the records on any step; see Configure flow step options.
- Set when the flow runs; see Schedule a flow.
- Turn the flow on and run it; see Run a flow.
