View Payments that have been fully applied (marked Applied under Status ) by clicking on the ID number.
Select Lockbox Invoices to view all the paid invoices for this transaction.
Important note: We recommend you refrain from using the Edit hyperlink for viewing records unless explicitly instructed to do so. It’s a much better practice to click on View or an “ID” hyperlink. This prevents an accidental edit and saves the step of cancelling out of the edit.
