Delete, restore, or purge a resource
Delete a resource — an export, import, connection, script, agent, stack, iClient, or API token — from the Resources page when you no longer need it. A resource can't be deleted while another resource or flow still uses it, so you remove those references first. A deleted resource goes to the Recycle bin, where you can restore it with its configuration intact until it's purged, either automatically at the end of your data retention period or by you. This article covers removing references, deleting, restoring, and purging. To delete a flow or an integration, see Delete a flow or Delete or restore an integration.
Prerequisites: You must have Manage permissions for the resource's integration, or be the account owner; see Manage user roles and permissions.
Remove references to the resource
A resource that's used by another resource or flow can't be deleted; integrator.io tells you so when you try. To find and remove the references:
  1. Go to Resources resources-icon.png, and then select the resource type, such as Connections.
  2. In the resource's row, select Actions elipses-button.png > Used by. The list shows every flow and resource that references it.
    Used by in the Actions menu
  3. Select an item in the list to open it, and then remove the resource from it or replace it with a different one. Repeat for each item.
    Used by list
A resource that requires a connection can't be left without one: when you remove a connection reference from an export, import, or lookup, replace it with another connection; see Change the connection in a flow or resource.
Caution: A connection that uses an iClient must be deleted and purged before you can delete the iClient. See Create an OAuth 2.0 iClient resource.
Delete a resource
  1. Go to Resources resources-icon.png, and then select the resource type.
  2. In the resource's row, select Actions elipses-button.png > Delete resource, and then confirm.
    Delete resource in the Actions menu
The resource moves to the Recycle bin, where it stays for your data retention period — 30 days by default — before it's purged; see Retain your log and error data for more than 30 days.
Restore a deleted resource
A resource in the Recycle bin can be restored until it's purged. The restored resource is available immediately, with the configuration it had when it was deleted.
  1. Go to Resources resources-icon.png, and then select Recycle bin.
    Recycle bin in the Resources menu
  2. In the resource's row, select Actions elipses-button.png > Restore.
    Restore in the Actions menu
Purge a resource
Purging removes a deleted resource from your account permanently; it can't be restored afterward. Resources in the Recycle bin are purged automatically at the end of the retention period, so purge one yourself only when it must be removed immediately — for example, a connection that's blocking the deletion of its iClient.
  2. In the resource's row, select Actions elipses-button.png > Purge, and then confirm.
    Purge in the Actions menu
