A journal entry record in NetSuite helps you track the total amount deposited by Amazon for a given settlement summary report. The settlement deposit date is considered as the journal entry record creation date.
A journal entry record might have the below transaction lines based on the settlement report:
- Amount deposited by Amazon: A line that displays the final Amazon settlement amount to be deposited in the bank account.
- Total transaction amount: A line that displays the amount only for “order” and “refund” related transactions.
- Total transaction amount for Refunds: A line that displays the total of the Customer Refund records in NetSuite that belong to the settlement, grouped by the account on each refund. The NetSuite Settlement Transaction to NetSuite Refund Add flow creates these refunds using the account in the NetSuite Refund Account setting (Settings > Settlement > Refund). If the Refund Add flow is off, this line isn't added.
- Total transaction amount for Payments: A line that displays the total of the Customer Payment records in NetSuite that belong to the settlement, grouped by the account on each payment. The NetSuite Settlement Transaction to NetSuite Payment Add flow creates these payments using the account in the NetSuite Payment Account setting (Settings > Settlement > Payment).
- Fees charged by Amazon: A line that displays the fee charged by Amazon based on the mappings you provide in the Map transaction fees to G/L account and Map non-transaction amounts to G/L account settings (Settings > Settlement > Journal Entry). A new line is added for every combination of Fee and G/L account.
Variance amount: A line that displays the difference amount between the Amazon deposit and reconciled amounts.
- Note: Variance = Total reconciled amount - Amazon deposit. The total amount is the sum of all the transactions.
For “Net amount deposited by Amazon” and “Variance amount” memo lines:
- If it is a +ve amount, debit from the bank account.
- If it is a -ve amount, credit to the bank account.
For any other memo line other than “Amount deposited by Amazon” and “Variance amount,”
- If it is a +ve amount, credit to the bank account.
- If it is a -ve amount, debit from the bank account.
Where each line's amount comes from
- Payment and refund lines: The journal entry doesn't read the NetSuite Payment Account or NetSuite Refund Account settings directly. It uses the Customer Payment and Customer Refund records in NetSuite that belong to the settlement, grouped by the account on each record. The settings matter because the NetSuite Settlement Transaction to NetSuite Payment Add and NetSuite Settlement Transaction to NetSuite Refund Add flows set those accounts on the records they create.
- If the Refund Add flow is off: No Customer Refunds exist for the settlement, so no separate refund line is added. The refund transactions stay in Unapplied status, and the refund amount typically becomes part of the Variance amount line, which posts to the account in the Variance Account setting.
- Refund fees: Fees such as Refund Commission aren't affected. They still post to the G/L accounts mapped in the Map transaction fees to G/L account setting.
- To show refunds as a separate line: Enable the NetSuite Settlement Transaction to NetSuite Refund Add flow.
Notes:
- You can delete the journal entry record and create it again for the same settlement summary report. To create the journal entry again, in the Celigo Amazon Settlement Summary record, uncheck the “Celigo Amazon Settlement Exported” box.
- If you do not find an appropriate fee type in the Map transaction fees to G/L account and Map non-transaction amounts to G/L account settings, you can manually enter values in the Amazon Amount Description field. You can map these values to any NetSuite G/L account. Any manual entry is added as a separate transaction line in the journal entry record.
For more information, see Manage journal entries in NetSuite.
Sample Celigo Amazon Settlement Summary
The amounts are grouped by fee type.
In the example below, there are multiple transaction lines for “Commission” and other types (Example: FBAPerUnitFulfillmentFee).
| Transaction type | Fee name | Total amount |
| Order | Commission | -3.75 |
| Order | FBAPerUnitFulfillmentFee | -3.3 |
| Refund | Refund Commission | -3.21 |
| Refund | FBAPerUnitFulfillmentFee | 3.45 |
| Refund | Commission | 3.89 |
See the table below to see how these similar transaction lines are calculated in a journal entry record.
Sample Journal
The transaction amounts for “Commission” and “FBAPerUnitFulfillmentFee” are summed and listed against a single line in the journal entry record.
| Account type | Debit | Credit | Memo |
| Amazon Bank Settlement Account | 8.42 | The amount deposited by Amazon | |
| Custom Refund Account | 31.75 | Total transaction amount for Refunds | |
| Custom Payments Account | 26.25 | Total transaction amount for Payments | |
| Reimbursement Account | 0.14 | Fee charged by Amazon for Commission | |
| Custom Payments Account | 0.15 | Fee charged by Amazon for FBAPerUnitFulfillmentFee | |
| Holding Account | 3.21 | Fee charged by Amazon for Refund Commission |
