Establish your NetSuite connection
You can establish your NetSuite account connection with the integrator.io account in the following ways:
  • With administrator access
  • Without administrator access
Set up the NetSuite connection with administrator access
You can assign the account ID you gave to install the Integration App to the administrator role. Enter the account ID in the Role ID field. The default internal ID for an administrator role in NetSuite is “3”.
Set up the NetSuite connection without administrator access
While installing an Integration App, if you do not want to associate the administrator role with the account ID, you need to ensure that the role ID is associated with the account ID that has the necessary permissions. The permissions allow the Integration App to access the required details from your NetSuite account.
Set up permissions for non-administrators roles in NetSuite
Each non-administrator can access the NetSuite record types that their role permits. Without the right permissions, errors will occur when you try to run data flows. For the user to set up, run, and maintain integrations in the Celigo integrator.io platform with a non-administrator role, you need to provide controlled access using the Permissions option in NetSuite.
Set up controlled permissions
  1. From your NetSuite account, go to Setup > Users/Roles > Manage Roles.
  2. On the Manage Roles page, click on the appropriate role you wish to customize.
  3. Click Customize.
  4. In the Permissions tab, ensure to enable the following permissions:
Section Permission Level
Transaction
Transactions Find Transaction Full
Transactions Cash Sale Full
Transactions Cash Sale Refund Full
Lists
Lists Accounts Full
Lists Currency Full
Lists Custom Record Entries Full
Lists Customers Full
Lists Documents and Files Full
Lists Items Full
Lists Locations Full
Lists Bins Full
Lists Subsidiaries Full
Lists Tax Items Full
Lists Payment Methods Full
Lists Perform Search Full
Setup
Setup Accounting Lists View
Setup Custom Body Fields
Full
Setup Custom Fields Full
Setup Custom Item Fields View
Setup Custom Lists Full
Setup Custom Record Types Full
Setup Custom Transaction Fields Full
Setup Other Custom Fields View
Setup Other Lists View
Setup SuiteScript Full
Setup User Access Tokens Full
Setup Web Services Full
Setup Custom Address Form View
Setup Custom Column Fields View
Setup Custom Entity Fields View
Setup Custom Sublists View
Setup Custom Transaction Forms View
Setup Customer Status Full
Setup Deleted Records Full
Setup Integration Application Full
Setup Manage Users Full
Setup SuiteBundler Audit Trail Full
Setup SuiteScript Scheduling Full
Setup Update Prices Full
Setup View Login Audit Trail Full
Setup Workflow Full
After you configure your establish your NetSuite connection, to configure your NetSuite connection with the Integration App, refer to Configure your NetSuite connection.
You can ask more questions about the Square Integration App installation in our community forum.
