Ignore specific errors in a postSubmit hook
This article explains how to use the postSubmit hook to ignore error messages in a flow.
Example: Customer import errors
This example syncs Shopify refunds with NetSuite.
Some imported customers have subsidiary value that should not be updated, and those records cause a specific error:
  "responseData": [
      "statusCode": 422,
      "errors": [
            "_userId": "5d93d813fe3c7b0ef52e58e8",
            "resolved": false,
            "code": "cant_modify_sub",
            "message": "Failed to save record because You cannot change the subsidiary of this entity because one or more transactions exist for this entity.",
            "source": "netsuite",
            "exportDataURI": null,
            "traceKey": "2178928902215"
      "ignored": false,
      "id": "ExampleID",
      "_json": {ExampleJSON},
      "dataURI": "ExampledataURI"
In such cases, you can use a conditional statement in a postSubmit hook to check for that specific error message and ignore it so that those errors do not generate notifications.
Add script to process error message (postSubmit script)
In the following postSubmit hook script, the highlighted conditional statement checks for the above error message and marks it as ignored:
function postSubmitNSCreateCustomerError(options) {
  let responseData = processPostSubmitErrors(options, ignoreCreateCustomerErrorFn)
  return responseData
function ignoreCreateCustomerErrorFn(options) {
  let toReturn = {ignored: options.ignored, betterMessage: options.message}
  //Check for specific error message inside "errors"    if (options.source === 'netsuite' &&       options.code === 'cant_modify_sub' &&      options.message.includes('Failed to save record because You cannot change the subsidiary of')) {   toReturn.ignored = true    toReturn.betterMessage = ''
  return toReturn
function processPostSubmitErrors(postSubmitOptions, myProcessErrorFunction) {
  postSubmitOptions.responseData.forEach(function(rd, i) {
    if (rd.statusCode !== 422) return
    let processedErrors = []
    rd.errors.forEach(function(re) {
      let errsHelper = []
      let parsedMessage = re.message
      try {
        parsedMessage = JSON.parse(re.message)
      } catch (ex) {}
      // Modify the following for your needs.
      if (typeof parsedMessage === 'object') {
        if (Array.isArray(parsedMessage)) {
          errsHelper = parsedMessage
        } else if (Array.isArray(parsedMessage.errors)) {
          errsHelper = parsedMessage.errors
        } else {
          errsHelper.push({code: re.code, message: re.message})
      } else {
      errsHelper.forEach(function(e) {
        let processedErrorMessage = myProcessErrorFunction({
          code: e.code || re.code,
          message: e.message || re.message,
          source: re.source,
          ignored: re.ignored,
          preMapDataRecord: postSubmitOptions.preMapData[i]
        processedErrors.push({
          message: processedErrorMessage.betterMessage || e.message || re.message,
          source: re.source,
          ignored: processedErrorMessage.ignored || re.ignored
    rd.errors = processedErrors
    let allErrorsIgnored = true
    for (let j = 0; j < processedErrors.length; j++) {
      if (!processedErrors[j].ignored) {
        allErrorsIgnored = false
        break;
    if (allErrorsIgnored) {
      rd.ignored = true
      rd.errors = []
      if (!rd._json) rd._json = {}
      rd._json.ignoredErrors = processedErrors
  return postSubmitOptions.responseData
Here is the preview of function output when you run the script inside the script editor:
Testing the code
The following animation demonstrates how to test the code:
