You can now clone the Integration App setting values and mappings from one integration tile to another integration tile within the same or different environments (production or non-production) with one store at a time. You can also clone settings from one store to other stores within the same integration tile using the same template. This utility provides you the feasibility to set the base store and destination stores as per your business needs. You can also choose to ignore the clone feature for any specific stores, settings, or mappings.
As of now, the cloning utility can be installed from the marketplace. This utility entails having an integrator.io license and an unused flow pack. In the future, it is pipelined to be available in the OOTB solution.
Legacy production and sandbox licenses
In legacy Production and Sandbox environments, changes in one environment affect both environments. The Production and Sandbox environments share the same underlying resources. Any resource you create, edit, or delete in one environment is immediately reflected in the other.
This includes connections, imports, exports, flows, scripts, and API tokens. Use caution when editing resources in either environment.
This behavior doesn't apply to accounts on the multi-environment license, where each environment maintains its own isolated resources.
Migrations from the legacy Production/Sandbox license to the new multi-environment license are underway. Your account has not migrated to the new multi-environment license if you can toggle between environments.
You can clone your integration app setting values and mappings:
One store to one or many available stores within the same integration tile
One store to another store in a different integration tile of the following environments:
Non-production to non-production
Production to production
Non-production to production
Production to non-production
Multi-store to multi-store within the same or different integration tile
You can clone your integration app setting values and mapping from one integration tile to another integration tile using the template for the US and EU marketplaces:
Clone Amazon - NetSuite integration app
Clone Magento 2 - NetSuite integration app
Clone Shopify - NetSuite integration app
You can clone your integration app setting values and mapping from one base store to one or many stores within the same integration tile using the template for the US and EU marketplaces:
Clone BigCommerce - NetSuite integration app
You can clone your integration app setting values and mapping from multi-store to multi-store within the same integration tile using the template for the US and EU marketplaces:
Limitations in the cloning template:
The cloning template will only work if you are using the same NetSuite account for both the source and integration tiles. For example, you cannot clone the source tile using NetSuite account ABC123 with the integration tile using NetSuite account XYZ234.
It won’t work in the scenario where different NetSuite accounts are used, as our architecture is solely based on internal ID and the name given for any field in NetSuite is not unique.
This template also won’t work between 2 tiles where one integration is pointing to a NetSuite sandbox environment and the other one is pointing to a NetSuite production environment.
Features not cloned and/or supported in the cloning template:
Saved searches in NetSuite
Any customizations in your NetSuite account
Sync data from one integration tile to another tile (including non-production to production and vice versa).
Any installed add-ons.
In the Amazon - NetSuite integration app, the multi-store cloning functionality is not available by default. For assistance in enabling it, contact Celigo Support.
Be sure that the required stores (base store and destination store) are already installed in the existing integration app.
If you are trying to clone setting values and mappings between different environments, be sure to have the Integration App installed in the production and non-production environments.
Before you set up your connection, log in as an account owner or an admin, and generate an access token at the account level from Resources > API Tokens.
Only for Magento 2: Before you run the flow in the Clone Magento 2 - NetSuite Integration App, be sure to refresh the Magento 2 version setting (Settings > General section > General tab) in the source and destination tiles.
The clone utility has been tested with a source integration app using the Standard Shopify edition and a target integration app configured with the Shopify Markets edition. All components are cloned successfully, except for the Payout tile. The Payout tile, along with its settings and mappings, must be configured manually.
Log in to your integrator.io account
On the left menu, click Marketplace.
Choose the appropriate integration, such as Amazon MWS, BigCommerce, Magento 2, or Shopify.
Based on the selected integration, click Install accordingly for one of the following:
Clone the Amazon - NetSuite template
Clone the BigCommerce - NetSuite template
Clone the Shopify - NetSuite template
You can preview the components that are packaged as part of the selected integration.
On the “Install template” window, click Install now.
You will be navigated to configure your integrator.io connection.
On the “Install app: Clone Amazon/Shopify/BigCommerce - NetSuite integration app page”, next to Step 1, click Configure.
On the “Set up connection” page, you can choose to set up either a new connection or an existing connection.
If you choose to Use Existing Connection, select the connection from the drop-down list.
If you choose to Setup New Connection, proceed with the below next steps.
In the Name field, enter your connection name.
In the “Application details” section, from the Region drop-down menu, select the appropriate region where the Integration App stores are present.
Enter the access token generated at the account-level with full access from Resources > API Tokens.
It is recommended to retain the Advanced Settings and Custom Settings as is.
In the Advanced Settings, ensure to select the value of the Concurrency level setting as “1.”
Test the connection and click Save and Close.
If an error is displayed while testing the connection, re-check your details; otherwise, contact Celigo Support.
You can find the custom settings in the “Settings” tab. You will find the following details:
sourceIntegrationID: Enter the source integration app ID from which you desire to clone the setting values and mappings in quotes.
sourceStoreName: Enter the source store name within quotes. This should be the store whose mappings and settings will be referenced for cloning within your integration tile.
Use this field only when cloning between stores within the same integration tile. Leave it blank if you intend to clone data across different integration tiles (e.g., from non-production to production).
mappingsNotToBeReplaced: Specify the mappings you don’t want to sync to the other integration store in quotes, separating each mapping by a comma. By default, a few mandatory mappings are specified. All the mappings are segregated below their respective import. The mappings are further segregated as “body-level” and “line-level.” Each list type will have its own grouping. For non-list (root level), the mappings are mentioned as body-level.
Below the “MappingsToBeReplaced” section, enter the internal ID of the fields from the backend code. You can find the actual field names from /imports/<import ID>. As per the import.json, for body-level mappings, refer to the fields at the body level, and for the line-level mappings, refer to the fields in any of the lists.
Settings to be ignored: Specify the label names that should not be cloned to the other integration stores. By default, all the settings related to saved searches, GST/VAT, and primary lookup criteria (to sync customers) are specified. As per your business needs, you can specify any other setting names that should not be cloned to the other store.
Notice
If you don’t want to clone the tax code to the other stores, you can add the appropriate setting label name Default tax code when no match is found in NetSuite, in this section.
Warning
Be sure to include the below settings that have NetSuite metadata dependency. Settings below the Settings to be ignored field.
NetSuite item to track order taxes as a line item
NetSuite discount item to track line discounts
The default tax code when no match is found in NetSuite
NetSuite locations to pick inventory from
Scenario 1: Store-to-store cloning within the same integration tile: The below setting is applicable only if you're cloning settings and mapping values for stores within the same integration tile:
sourceIntegrationID: Enter a unique integration ID.
sourceStoreName: Enter the source store name in quotes. This action will clone all settings and mapping values for all the stores in the same integration tile. Leave this field blank if you want to clone from one tile to another tile.
storesToBeIgnored: By default, the value of this setting is empty. If you wish to ignore the cloning for any of the stores, mention the store names in this setting. If you do not mention any store name in this setting, the settings and mappings are cloned from the source store to all the other available stores within the integration tile.
Enter the input details in an array format. Enter each value in quotes separated by a comma.
Scenario 2: Cloning from one integration tile to another integration tile: The below settings are applicable only if you're cloning setting and mapping values for stores from one integration tile to another integration tile:
destinationIntegrationID: Enter the destination integration app ID to which tile you wish to clone the data. Enter the destination integration ID in quotes (“integration ID“).
Destination store name: Enter the destination store name.
If you don’t provide any destination store name, an error message is displayed.
Enter a unique integration ID in the sourceIntegrationID and destinationIntegrationID fields if you wish to clone data between different integration tiles.
If you enter the same ID in the sourceIntegrationID and destinationIntegrationID fields, the setting values and mappings are cloned from the source store to other available stores (if any) within the same integration tile.
Scenario 3: Multi-store to multi-store within the same or different integration tile: The settings below are applicable only if you're cloning the settings and mapping values for stores between 2 integration tiles. If you are cloning the setting and mapping values for stores in the same integration file, ensure the value in the “sourceIntegrationId” and “destinationIntegrationId” fields should be the same.
sourceDestinationStoreMap: Mention the source store name on the left-hand side in quotes and the destination store name on the right-hand side in quotes, separated by a colon (as highlighted in the image below)
If you enter the source store name in this field, any values entered in the “sourceDestinationStoreMap” and “destinationIntegrationId” fields will be ignored.
storesToBeIgnored: Enter the destination stores which should be ignored in quotes, separated by a comma.
You can enter values in both the sourceStoreName and storesToBeIgnored fields to clone the setting and mapping values for the stores in the sourceIntegrationId field.
Fields to use if cloning within the same tile: sourceStoreName, storesToBeIgnored, sourceIntegrationId
Fields to use if cloning from one tile to another: sourceIntegrationId, destinationIntegrationId, sourceDestinationStoreMap
To run the Sync base store setting values to other stores flow.
Next to the respective flow, click on the on/off toggle button to enable the “Sync base store setting values to other stores” and “Sync base store mappings to other stores” flows.
Click Run.
The “Sync base store mappings to other stores” flow automatically runs after the “Sync base store setting values to other stores” flow, as it is a sequenced flow.
