eBay documentation: API guide , Authentication
Verify that you are signed in to eBay as the account owner when setting up a connection.
Start establishing a connection to eBay (XML) in either of the following ways:
From the Resources menu, select Connections. Then, click + Create connection at the top right.
– or –
While working in a new or existing integration, you can add an application to a flow simply by clicking Add source or Add destination/lookup.
In the resulting Application list, select eBay (XML).
The Create connection pane opens with general and advanced settings.
The Application details section contains additional settings for eBay (XML) authentication.
Account Type: Select either the Production or Sandbox environment.
API site id (required): Enter the eBay API site ID.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the eBay (XML) connection.
Save & authorize – click to save the connection and exit the Create connection pane.
Cancel – click to exit without saving any new changes.
Enter your email and password and click Sign in.
Click Agree to establish the connection.
