Move flows to or from an integration
Use this article to move flows between integrations. Orphaned flows are moved to an integration called Standalone Flows.
You can also view and manage all your flows across integrations from Build > Flows in the left navigation.
  • Standalone flows: flows previously created without an integration (identifiable by integrations/none/flows in the URL) — are no longer supported. All existing standalone flows have been automatically migrated to an integration called Standalone Flows. No action is required on your part.
Prerequisites
You must have Manage access to both the source and destination integration tiles. If you have only monitor access to either integration, the Move option is not available.
Move flows between integrations
You can move a flow between two integrations. You can always move a flow back to its original integration if needed.
  1. Open the integration that contains the flow you want to move. You can also access flows across all integrations from Build > Flows in the left navigation.
  2. Select the Actions (...) icon for the flow, then select Move.
  3. Select an existing integration or create a new integration.
Related articles
