Set up a connection to Domo
Domo is a cloud-based business intelligence (BI) platform that connects data from across your organization to deliver real-time insights through interactive dashboards.
This video demonstrates creating a DOMO connection.
Setting
Instructions
Name your connection *
API type *
Choose your Domo account API type:
  • Platform API: Connect to automate admin tasks, control access, and integrate platform-level operations with other systems.
  • Product API: Connect to build interactive user experiences, embed Domo content, and extend the platform with tailored business solutions.
Auth type *
Select your Domo account authentication type (either Basic or OAuth 2.0).
Auth type: Basic
Username *
Enter your Domo account username.
Password *
Enter your Domo account password.
Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Auth type: OAuth 2.0
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Domo.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit (pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource
Scope *
Scopes are OAuth 2.0 permissions that Domo defines to limit access to your account.
How to configure scopes
API type: Domo Product API
Subdomain *
Enter your Domo account subdomain. For example, if your Domo account URL is https://celigo-1.domo.com/, then celigo-1 is the subdomain.
Access token *
Enter your Domo API key.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic and OAuth universal connector documentation.
  1. Sign in to your Domo developer portal.
  2. Navigate to Developer > Manage Client IDs.
  3. Click Create a client.
  4. Enter a client Name.
  5. Enter a Description.
  6. Select the Application scope.
  7. Click Create.
  8. Copy the Client ID.
  9. Copy the Client secret.
How to retrieve the access token
  2. Navigate to More > Admin > Authentication > Access tokens.
  3. Click Generate access tokens.
  4. Enter a token Name.
  5. Enter a token Description.
  6. Click Generate.
  7. Copy the Access token.
  1. Click Scope.
    – or –
  3. Click Save.
Additional references
