Databricks is a unified data analytics platform that enables organizations to process, analyze, and visualize big data.
API type * |
Choose your Databricks account API type:
Account ID * |
Enter your Databricks account ID. |
API version (if API type is Account) |
Select your Databricks account API type (2.0, 2.1, or 2.2). |
Domain * (if API type is Workspace) |
Enter your Databricks account domain. For example, if your Databricks account URL is |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Databricks. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Scopes |
Scopes are OAuth 2.0 permissions that Databricks defines to limit access to your account. |
Sign in to your Databricks account.
Navigate to Profile avatar > My Account
Copy the Account ID.
Navigate to Settings > App connections.
Click Add connection.
Enter an Application name.
Enter the Celigo integrator.io Redirect URL.
Check the required AccessScopes.
Check Generate a client secret.
Click Add.
Copy the Client ID.
Copy the Client secret.
