The dateFormat helper converts a date into a specified output format, and can optionally parse a custom input format and apply a time zone. Builders use it in Handlebars templates — including field mappings, response mappings, HTTP request bodies, and dynamic API paths — to reformat timestamps or convert them to a specific time zone.
Usage
{{dateFormat oFormat date iFormat timezone}}
oFormat -- The output format for the result, using moment.js format codes, for example "MM-DD-YYYY HH:mm" or "YYYY-MM-DDTHH:mm:ssZ". Required.
date -- The date to format, as a field reference such as record.orderDate or a date string. Required.
iFormat -- The format of the input date, using moment.js format codes, for example "YYYY-DD-MM HH:mm". Provide this when the input isn't in ISO 8601 or another automatically recognized format. Optional.
timezone -- A valid IANA time zone identifier, such as "America/Los_Angeles". When oFormat includes Z, the output shows the corresponding time zone offset. Optional.
Examples
Format an ISO date in US style
{{dateFormat "MM-DD-YYYY hh:mm A" record.orderDate}}
If record.orderDate is "2025-03-26T12:34:56Z", the output is "03-26-2025 12:34 PM".
Parse a custom input format
The day in "1966-25-05 18:36" is in the middle, so iFormat tells the helper how to read it.
{{dateFormat "MM-DD-YYYY HH:mm" record.orderDate "YYYY-DD-MM HH:mm"}}
If record.orderDate is "1966-25-05 18:36", the helper reads it as May 25, 1966 and outputs "05-25-1966 18:36".
Apply a time zone
{{dateFormat "YYYY-MM-DDTHH:mm:ssZ" record.orderDate "" "Asia/Hong_Kong"}}
This converts record.orderDate to Hong Kong time and includes the offset (+08:00) in the output, because oFormat ends with Z. The empty string for iFormat preserves the positional order so that timezone is read correctly.
Notes and constraints
- Common tokens include
YYYY(year),MM(month),DD(day),HHorhh(hour),mm(minute),ss(second),Aora(AM or PM), andZ(time zone offset). For the full list, see Time and date format codes. - Provide
iFormatonly when the input isn't in ISO 8601 or another recognized format. Omit it for standard ISO 8601 inputs. - When
oFormatincludesZ, the offset reflects thetimezoneyou provide. Without a time zone, the result is in UTC. - Time zone identifiers use IANA naming, such as
"America/New_York"or"Europe/London". - Because the parameters are positional, pass an empty string (
"") foriFormatto specify a time zone without a custom input format.
