The timestamp helper generates the current date/time string in a specified format and timezone. If you omit the format, the helper uses an ISO8601 default. If you omit the timezone, it defaults to UTC rather than using any profile-based settings.
{{timestamp format timezone}}
format (optional): The date/time format pattern (e.g.,
"YYYY-MM-DD HH:mm:ss"or"HH:MM:SS"). Defaults to ISO8601 if not specified. -
timezone (optional): A valid timezone identifier (e.g.,
"America/Los_Angeles"). Defaults to UTC if not specified.
Display local time in Los Angeles
{{timestamp "HH:MM:SS" "America/Los_Angeles"}}Example output:
08:09:09(local time with offset). -
Use a custom format in UTC
{{timestamp "YYYY-MM-DD HH:mm:ss"}}Generates:
2025-04-20 17:38:20in UTC.
Always specify the
timezoneparameter to avoid confusion with default timezones. -
Check which date/time format tokens are supported in your Celigo environment (typically ISO-style or standard format strings).
If you need to manipulate dates further (e.g., add days/hours), consider other date/time helpers that might be available, or handle the logic before calling
timestamp.
