Use the split helper to break a string into an array of substrings based on a specified delimiter. You can optionally return a single element from the resulting array by providing its 0-based index.
{{split field delimiter [index]}}
field: The field or variable containing the string to split (e.g.,
record.fullName). -
delimiter: The character(s) used to split the string (e.g.,
index (optional): Zero-based index indicating which substring to return. If omitted, the helper returns the substring at index 0.
Getting specific parts of a name
If
record.fullNameis"Hillary-Ann-Swank", then:{{split record.fullName "-" 0}} → Hillary {{split record.fullName "-" 1}} → Ann {{split record.fullName "-" 2}} → Swank -
Returning substring at position 0 (no index)
{{split record.fullName "-"}}Produces substring at index position 0 (e.g.,
"Hillary").
If the delimiter does not appear in the string, the helper returns the string itself (or an empty result if the string is empty).
Double-check that the delimiter matches exactly what you expect (e.g., a space vs. a hyphen).
Use triple braces (
{{{ }}}) if you prefer raw, unformatted output of the resulting comma-separated list.
