The unique helper returns a new array with all duplicate values removed. Use it with #each or other rendering helpers to process or display only distinct values.
Remove duplicates from a string array
{{#each (unique record.tags)}}{{this}}{{#unless @last}},{{/unless}}{{/each}}
Input:
{ "record": { "tags": ["a", "a", "c", "b", "e", "e"] } }
Output:
a,c,b,e,
Use with nested data
{{#each (unique record.categories)}}
{{this}}
{{/each}}
Input:
{ "record": { "categories": ["A","B","A","C","B"] } }
Output:
A B C
Preserves the original order of first occurrences.
Works only for arrays of primitive values (strings, numbers, booleans).
Use this helper to eliminate duplicates before iterating or combining results from multiple data sources.
