hasNoItems helper
Returns true if the input collection (array or object) has no elements or properties.
Usage
{{hasNoItems value}}
  • value (required): The array or object to evaluate
Examples
Check for empty arrays and objects
{{hasNoItems record.arr1}}
{{hasNoItems record.arr2}}
{{hasNoItems record.obj1}}
{{hasNoItems record.obj2}}
Input:
  "record": {
    "arr1": [],
    "arr2": [1, 2],
    "obj1": {},
    "obj2": { "x": 1 }
Output:
true
false
true
false
Conditional rendering example
{{#if (hasNoItems record.items)}}
  No items found
{{else}}
  Items present
{{/if}}
Input:
{ "record": { "items": [] } }
Output:
No items found
  • Works for both arrays and plain objects.
  • Returns true only when there are no elements (for arrays) or no keys (for objects).
  • Use with #if or #unless for conditional logic when checking for empty collections.
