The isTruthy helper returns true when the input has a meaningful value, and false when it is absent or empty. Use it to check that a field is present before you map it, or to drive a conditional block.
Syntax
{{isTruthy value}}
value -- The value to evaluate. Required.
Values that return false
| Value | Type |
false |
Boolean |
0 |
Integer |
Empty string |
null |
Null |
undefined |
Undefined |
NaN |
Not a number |
All other values -- non-empty strings, non-zero numbers, arrays, and objects -- return true.
Examples
Evaluate a mix of present and absent values
{{isTruthy record.a}}
{{isTruthy record.b}}
{{isTruthy record.c}}
{{isTruthy record.d}}
{{isTruthy record.e}}
Input:
"record": {
"a": 1,
"b": 0,
"c": "hello",
"d": "",
"e": null
Output:
true false true false false
record.a (1) and record.c ("hello") have meaningful values, so they return true. record.b (0), record.d (""), and record.e (null) are absent or empty, so they return false.
Use in a conditional block
{{#if (isTruthy record.status)}}
Active
{{else}}
Inactive
{{/if}}
Input:
{ "record": { "status": "enabled" } }
Output: Active
Wrap isTruthy in parentheses to use it as an inline expression inside #if. The same template renders Inactive when record.status is "".
Usage notes
- Wrap
isTruthyin parentheses when using it as an inline expression:{{#if (isTruthy value)}}. - The string
"0"and the string"false"are non-empty strings and returntrue. Only the integer0and the booleanfalsereturnfalse. - To check whether a value is absent rather than present, use the isFalsey helper instead.
#someacceptsisTruthyas a condition name. That test applies to each element of an array. See the #some helper.
