Template flow visualization
Celigo Platform Marketplace is enhanced with the new Template flow visualization preview, offering a full-screen, interactive experience that lets you explore pre-built integration templates before installation. This feature helps quickly understand the structure and logic of a template, making it easier to identify and select the right integrations from the Marketplace.
This enhanced visualization offers Module-based grouping of flows for intuitive navigation and lets you select Flow names to open a read-only Flow Builder view built on Celigo’s new design system.
The preview provides a comprehensive visual breakdown of flow steps, including exports, imports, filters, mappings, and more. You can also view key details such as:
  • Source and destination applications and their icons.
  • Mappings, filters, and scripts (non-editable).
  • Branching, lookups, and hooks used within the flow.
To experience this feature:
  1. Sign in to your Celigo account.
  2. Navigate to Marketplace.
  3. Search the required template By application/By type.
  4. From the search results, select the required template or select one from the Featured templates suggestions.
  5. Select Preview.
    • The left pane displays the list of Flows, Integrations, connections, Imports, and Exports.
  6. Select the required flow or the View icon to open the Flow Builder page.
    • You can view all related Exports, Lookups, Mappings, Transformations, Hooks, and more.
    • You can explore the flows to get a deeper understanding of the template components.
  7. Select Read Me to view the documentation for that specific template.
  8. Select Install template to install and access the template.
