Jump-start integrations with templates and apps
The integrator.io Marketplace lists integration apps, templates, MCP templates, AI agents, and Ora-guided templates that you can install in your account. Use the filters to find a listing for the applications you use, then install it to start your integration with prebuilt components instead of building from scratch.
Marketplace listing types
Type What it is How you install it
AI agents Prebuilt agents that use AI reasoning to complete multi-step tasks across your applications. Choose one when a task requires judgment, not only moving data. Same as templates: select Preview, then Install now. See AI flow templates.
Integration apps Licensed solutions managed by Celigo or a certified partner, with guided setup and automatic updates. Choose one when it supports your applications and you want Celigo or the partner to maintain it. Requires a license. See Integration apps.
MCP Ready-made MCP servers for the apps you already use. Choose one when you want AI agents and MCP clients to call those apps as tools. See Find and install an MCP server template from the Marketplace.
Templates Prebuilt flows, connections, and mappings that you own and customize. Choose one for more flexibility, or when no integration app supports your applications. Select Preview, then Install now. See Install a quickstart integration template.
Ora guided Templates that Ora sets up with you, step by step. Their tiles show an Ora badge. Select Install on the tile. See Celigo Ora overview.
To see these descriptions in the Marketplace, hover over What's the difference? under By type.
Find a listing in the Marketplace
  1. Go to Marketplace Marketplace icon.
  2. To find a listing by name, enter it in Search Marketplace.
  3. To filter by listing type, select types under By type. Ora guided narrows your other selections, so keep at least one other type selected.
  4. To filter by application, select your applications under By application. Use Popular for common applications or All for the full list, and search with Find an application. To reset your selections, select Clear, which shows how many applications are selected.
  5. To change the order, select Most popular, Most recent, Alphabetical (A → Z), or Alphabetical (Z → A) in Sort.
Templates
Quickstart integration templates are bundled integrations between two existing applications. For example, you can install a 3PL Central – NetSuite integration from its template in the Marketplace. Integration templates provide predesigned components for integrations between applications.
Components
These components are available for each template:
  • Flows: Transfers data from a source application to a destination application
  • Integrations: The container that groups the template's flows and connections
  • Connections: Connected applications
  • Imports: Data imported to an application
  • Exports: Data extracted from an application
Install a template
You install a template from its preview page, where you can review its components and Read me before you select Install now. AI agent templates install the same way. For the steps, see Install a quickstart integration template.
Note: To install an Ora-guided template, select Install on its tile, not on the preview page. See Celigo Ora overview.
Integration apps
Integration apps package a complete integration between applications and require a purchased license. To get started, select Request demo on the app's tile. If your account already has a license, the tile shows Install. The installation steps vary by integration app, so follow the app's documentation to install it. For licensing and installing across environments, see Install and manage integration apps across environments.
