Celigo platform editions
The Celigo platform offers scalable editions that cater to a range of automation needs, from basic workflows to enterprise-wide integrations. Each edition offers varying levels of performance, security, governance, and support tailored to meet specific business requirements. This article outlines the capabilities available in each edition to help you select the one that best suits your organization’s needs.
Standard
This edition is ideal for teams who want to begin by integrating critical applications and need essential automation with reliable performance.
  • Provides a baseline set of integration and automation capabilities.
  • Performance is aligned with the API limits of connected applications.
  • Includes multi-factor authentication (MFA) and role-based access controls, with the option to add on single sign-on (SSO).
  • Comes with a standard support package that includes defined service-level agreements (SLAs) at no additional cost.
Professional
This edition is suited for organizations that are scaling integrations across multiple departments and require advanced capabilities.
  • Designed for managing integrations across multiple teams or departments.
  • Supports advanced features such as API Builder and Lookup Cache.
  • Includes role-based access controls, SSO, and audit logs for tracking activity.
  • Provides a non-production environment for development and testing.
  • Enhanced support package with defined SLAs at no additional cost.
Enterprise
This edition is ideal for large enterprises requiring unlimited scalability, maximum performance, and comprehensive compliance support.
  • Intended for organization-wide integration and automation at scale.
  • Allows an unlimited number of endpoints.
  • Increases the concurrency limit to 50.
  • Optimized to support high-volume operations.
  • Provides advanced governance, security, and audit capabilities to support compliance needs.
  • Includes the highest level of support package with the fastest SLA response times at no additional cost.
Celigo platform capabilities by edition
Capability Standard Professional Enterprise
Flows 20 20 20
Endpoints 3 3 Unlimited
Concurrency 25
50
Available as an add-on only
50
AI credits
Initial capacity included
Additional capacity – Available as an add-on
Used by Celigo-hosted models only
On-premise agent Available as an add-on Available as an add-on Available as an add-on
On-premise agent groups (high availability) Not available Not available Available
SSO Available as an add-on Available Available
Audit logs 1 year 2 years 3 years
Log retention 30 days 60 days 180 days
Execution logs
Basic
Detailed – Available as an add-on
Debug
Basic
Debug
Basic
Detailed
Debug
Environments Production: 1
Production: 1
Non-production: 1
Production: 1
Non-production: 2
AI agents Available Available Available
MCP management Available Available Available
Lookup cache Available as an add-on Available Available
SCIM Not available Not available Available
Change data capture (CDC) Not available Available Available
Multi-instance flows Not available Available Available
File storage 1 GB/month 100 GB/month 200 GB/month
SFTP file server Not available Available Available
File query Not available Available Available
Topics Not available Available Available
API Builder Available as an add-on Available Available
Support package Essential Preferred Premier
Celigo Liftoff seats Not available 2 5
Data ingestion
Data ingestion, delivered through Celigo sync, moves operational data from your source applications into an analytical destination such as Snowflake, Google BigQuery, or NetSuite Analytics Warehouse (NSAW). Each environment can have one active sync, unless your subscription includes add-on DI volume. Your monthly record load limit depends on your edition.
  • Standard
    • 500K records per month
  • Professional
    • 2.5M records per month
  • Enterprise
    • 5M records per month
Every record a sync loads to its destination counts toward your monthly DI volume. To use less, use Delta extract mode. For what counts and how to track it, see Track your DI volume usage.
** Add-ons
  • Data ingestion volume packs. To add DI volume, go to Account > Subscription, select Request upgrade, and open a ticket with Celigo Support.
For more information, see Celigo sync overview.
API Management
While API Builder is included in Professional and Enterprise and available as an add-on in Standard,  API Management is a separate subscription that has two tiers, Standard and Advanced.
  • APIM Standard
    • Dev portal, logging, analytics, policy studio
    • 10M calls per month
  • APIM Advanced
    • APIM Standard +
    • 100M calls per month
    • Advanced policy set
For more information, see API Management.
B2B Manager
Tier name Basic Advanced Expert
Number of trading partners 3 10 25
Number of document types 5 5 5
** Add-ons
  • Trading partner packs: 1, 5, 10
  • Document type packs: 1, 5, 10
  • VAN subscription tiers based on usage
For more information, see B2B Manager.
