All article conventions follow Celigo technical style for consistency and clarity.
Convention |
Description |
Example |
Articles in this section |
A menu that displays all the articles included in the selected section of the knowledge base. They appear to the left of the article on most screen resolutions. |
Avatar |
Your avatar displays your image and, when selected, shows all your associated tickets, comments, and community posts. |
Bold |
“Bolded” words create emphasis and reference the name of a button or resource in integrator.io. |
Click Create and select integration (or) Click Settings |
Breadcrumbs |
Breadcrumbs display your current location in the Help Center and display the hierarchy of documents in the section. |
Created/updated date and author |
The name, image, and update day for the document. |
Kathyana Rule updated this article one month ago. |
Icons |
Icons are used sparingly to display a specific button a user should click. For example, the settings icon. |
Jump links |
Links that open other articles or web pages in a new tab or window are designated by a jump link icon. |
Naming Conventions |
Trademarks are styled per the application’s branding guidelines |
NetSuite, BigCommerce, eBay |
File types are always capitalized |
PDF, CSV, EDI |
Proper nouns are always capitalized. |
Welcome to Celigo. Select the connector, connection, or Integration App you would like to use. |
Sample data |
Sample data is written in an inline monospace variant with a gray highlight to distinguish it from the rest of the article. |
My Object |
Titles |
Article titles are always in sentence case – meaning only the first word is capitalized |
Article title: Map source record fields to destination |
Underlines |
Underlines designate a link on hover. |
