Understand the Employee Onboarding and Offboarding business process automation for SAP SuccessFactors
"Employee Onboarding and Offboarding for SAP SuccessFactors" business process automation focuses on the employee lifecycle in a company. This template lets you provision and deprovision users from SAP SuccessFactors into one or more applications where SAP SuccessFactors acts as a hub and the source of truth for an employee record.
Features and benefits
  • Set of prebuilt unmanaged integration flows for quick start and easy customization between different applications and SAP SuccessFactors.
  • Ability to pick and choose destination applications during and after installation of the template.
  • Save time and minimize errors by eliminating manual data entry.
  • Provisioning and Deprovisioning flows are batch flows.
Supported integration flows
The Celigo template contains integration flows that you can configure and deploy without coding or IT support. The following built-in flows sync from the specified source data to the corresponding destination.
Flows What’s not supported
Provisioning: Provision user access from SAP SuccessFactors
Updating user details in destination applications.
Note: Support for updates can be achieved by changing import configuration.
Deprovisioning: Deprovision user access from SAP SuccessFactors
Removing the user from all the applications.
Error handling
integrator.io error messages will clearly explain the error and suggest troubleshooting methods. If you are unsure of what the error means, contact Celigo support.
