Configure and run flows in the Employee Onboarding and Offboarding business process automation for SAP SuccessFactors
The Employee Onboarding and Offboarding business process automation for SAP SuccessFactors comprises a set of pre-built integration flows. These flows help you to sync and unsync the information of employee details between SAP SuccessFactors and various applications.
Before you begin
  • You need to have SAP SuccessFactors credentials.
  • Generate employee data from SAP SuccessFactors.
  • The connections should be online to run the flows.
Limitations and known issues
  • You will not be able to view the Add application option in the Settings tab for cloned integrations.
  • For cloned flow, the addition of import is not supported through the Add application setting. The desired applications can be added only to the original flow.
  • To delete the tile, you will first have to delete the flows and then the imports and exports.
  • Ensure the connection status of the destination application is online, if it is not then the flow discontinues which will affect the subsequent applications.
  • Other applications not listed in the supported prebuilt destination applications can be added as imports through the Flow Builder.
Provisioning flow: Provision user access from SAP SuccessFactors
This flow helps you to sync new and activated employees created in SAP SuccessFactors to all selected applications and give relevant access to the user.
Setup Instructions
Configure output
Get employees from SAP SuccessFactors: Here, you can retrieve all the employees from SAP SuccessFactors through API.
Configure API Name and Operation fields. You have Delta type as an option for exporting the employee information.
Configure input app(s)
Employee Onboarding and Offboarding business process automation for SAP SuccessFactors supports 6 applications as end points. Each of the applications have their unique set up for mappings.
Okta:
  • Configure mandatory mappings for profile.email and profile.login in Import field (Okta).
  • The provisioned user will receive an activation email once the user is created.
NetSuite:
  • Configure mandatory mappings for Subsidiary (InternalId, Currency, Give Access, Roles: Role (InternalId) in the Import field (Netsuite).
  • Configure the Relative URI with the organization name.
Salesforce:
  • Configure mandatory mappings for Email, Username, Alias, Profile ID, Time Zone, Locale and Language in the Import field (Salesforce).
  • On configuring the trigger in your salesforce account, the provisioned user will receive an activation email once the user is created.
SAP Concur Expense:
  • You need to establish a connection between the Concur and Celigo app by following the below steps:
  1. Login to SAP Concur with your credentials.
  2. Go to the App Centre.
  3. Search for Celigo app and select Connect.
  • Configure mandatory mappings for FeedRecordNumber, Custom21, CtryCode, CrnKey, LedgerCode, LocaleName and LedgerKeyUsername in the Import field (Concur).
Microsoft Entra ID:
  • Configure the userPrinciplename mapping by providing the unique logon name and the domain name.
  • No email is sent in the form of notification.
Litmos:
  • Configure mapping for ActiveAccessLevelIsCustomerUsernameSkipLoginEmail and Password for your Litmos configuration in the Import field (Litmos).
Deprovisioning flow: Deprovision user access from SAP SuccessFators
Deprovisioning flow helps you to sync inactive or deactivated employees in SAP SuccessFators to all selected applications and revoke access from the user.
Setup Instructions
Configure output
Employee Onboarding and Offboarding business process automation for SAP SucessFactors supports 6 applications as end points. Each of the applications have their unique set up for mappings.
Okta: The default mapping for inactive is true for your Okta configuration in the Import field (Okta).
NetSuite: The default mapping for inactive is true for your NetSuite configuration in the Import field (NetSuite).
Salesforce:
  • By default, the search criteria for the userId lookup is based on the user’s email id. You will need to configure this if the requirement for your organization differs from the default.
  • The default mapping for IsFrozen is true for your Salesforce configuration in the Import field (Salesforce).
SAP Concur Expense: The default mapping for active is N for your Concur configuration in the Import field (Concur).
Microsoft Entra ID: The default mapping for accountEnabled is false for your Azure configuration in the Import field (Azure).
Litmos:
  • Configure lookup mapping for id for your Litmos configuration in the Import field (Litmos).
  • The default mapping for active is false for your Litmos configuration in the Import field (Litmos).
Both the flows and integrations can be cloned. Refer to Clone flows and integrations.
Add application(s)
To add a new application follow the below steps:
  • Register the connection for the application you wish to add by navigating to the Connections tab. For more details, refer to Register connection.
  • Navigate to template settings by selecting on Settings tab.
  • Select the Provisioning tab in Settings if you wish to add a new application to provision user access from SAP SuccessFactors. Select the Deprovisioning tab in Settings if you wish to add a new application to deprovision user access from SAP SuccessFactors.
  • Select the application from the Add application dropdown.
  • Navigate to the Flows tab and select the flow group and then the flow to view and configure the additional applications.
Remove application(s)
To remove an application follow the below steps:
  • Navigate to the Flows tab and select the flow from which you want to remove the application.
  • Remove the import bubbles for the application you wish to remove.
