Acquia is a cloud platform for building, hosting, and optimizing Drupal websites, helping teams manage content, deliver secure digital experiences, and scale performance for enterprise needs.
The Acquia connector is in BETA and may be subject to changes.
API type * |
Choose your Acquia API type.
API type: DAM V1 and DAM V2 |
My site * |
Enter your Acquia application site name. |
Auth type * |
Select your Acquia authentication type (Basic, Token, or OAuth 2.0). |
Basic authentication |
Username * |
Enter your Acquia account username. |
Password * |
Enter your Acquia account password. |
Token authentication |
Token * |
Enter your Acquia token. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
OAuth 2.0 authentication |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Acquia support. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Grant type * |
Select your OAuth 2.0 grant type (either Authorization code or Password credentials). |
API type: Web governance |
API region * |
Select your Acquia API region:
Token * |
