Set up a connection to Infobip
Infobip is a global cloud communications platform that helps businesses send and manage customer interactions across channels like SMS, WhatsApp, email, voice, and push notifications, all through APIs and a single platform.
Setting
Instructions
Name your connection *
Subdomain *
Enter your Infobip account subdomain. For example, if your URL is https://4kmdgm.api.infobip.com, then 4kmdgm is your subdomain.
Auth type *
Select your Infobip account authentication type (Token or Basic).
Auth type: Token
API key *
Enter your Infobip API key.
Auth type: Basic
Username *
Enter your Infobip account username.
Password *
Enter your Infobip account password.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the respective documentation for OAuth 2.0 auth and Basic auth universal connectors.
How to retrieve the API key
  1. Sign in to your Infobip account.
  2. Navigate to Developer tools > API keys.
  3. Click Create API key.
  4. Enter a Name.
  5. Select the API scopes.
  6. Click Create.
  7. Copy the API key.
In addition to basic authentication, API access must be enabled from the user’s dashboard. Navigate to Profile > User profile > Access controls > API access, and select the appropriate protocols to allow basic-authentication user access.
