Cancel a run when a flow is processing records it shouldn't, is stuck behind a slow application, or was started by mistake. Canceling stops the run where it is; it doesn't undo anything the run already wrote to the destination. This article explains what cancellation does, how to cancel from the Dashboard, and how to stop a scheduled flow from starting at all.
Prerequisites: You must have Manage permissions for the integration; see Manage user roles & permissions to an account. Only a run that is queued or in progress can be canceled; a run that has completed or failed can't be, and a scheduled run that hasn't started isn't a run yet — turn the flow off instead (see below).
What cancellation does
- Cancellation is asynchronous: the run shows Canceling briefly, then Canceled.
- Records the import has already written stay in the destination. Cancellation doesn't roll them back.
- A canceled run can't be resumed. Running the flow again starts a new run, and the records the canceled run already wrote can be exported again — a create-only import may produce duplicates, so design imports that match and update existing records to handle reprocessing.
- Canceling a delta export's run doesn't advance its checkpoint. The next run reads from the last successful run's checkpoint, not from the canceled run's start: if the checkpoint is 9:00, a 10:00 run is canceled, and the next run starts at 11:00, that run retrieves the changes from 9:00 to 11:00 (subject to any lag you've configured).
- Canceling stops the current run only; the flow's schedule and future runs are unaffected.
- A run that shows In progress for a long time may be waiting on the source or destination application rather than stuck. Check the application's status before you cancel.
Cancel a run
- Go to Dashboard
- Under Running flows, find the flow.
- Select the flow's Actions
> Cancel run. To cancel one job rather than the whole run, select the In progress status to open Queued jobs and cancel the job there.
The run's status changes to Canceling, then Canceled, and the run moves to Completed flows. If it still shows Canceling after a few minutes, refresh; if it doesn't change, contact Celigo Support.
In Flow builder, you can also cancel a run from the Run console below the canvas: in the run's row, select the cancel icon under Actions, and then select Cancel job. This cancels the whole run. The flow's Run history tab offers the same action and shows who canceled each run; see View a flow's run history.
Stop a scheduled flow from running
A run that hasn't started can't be canceled. To keep a flow from running at its next scheduled time:
- Go to Home
, open the integration, and then select Flows.
- In the flow's row, turn off Enabled
The flow doesn't run on its schedule or on demand until you turn it back on. To keep the flow on but stop automatic runs, remove its schedule instead; see Schedule a flow.
