Download a flow as a ZIP file to keep a copy of its configuration, read the JSON behind it, or hand it to someone who will install it in another account. The ZIP holds the flow and the resources it's built from, but not the connections or any data. This article covers downloading a flow and what the file contains. To download a whole integration, see Install integration or download integration ZIP file.
Download a flow
- Go to Home
, open the integration, and then select Flows.
- Select the flow's Actions
> Download flow.
The browser saves the ZIP file to its download location.
What the ZIP contains
| Included | Not included |
| The flow: name, schedule, settings, and the order of its steps | Connections — whoever installs the flow configures their own |
| Each export, with its settings, filters, and transformations | Run history, errors, and audit logs |
| Each import, with its settings, mappings, and lookups | Files in Celigo Storage, queued records, and data in transit |
| Scripts the flow references | Messages in any topic the flow uses |
| The configuration of topics the flow publishes to or subscribes to |
When the ZIP is installed, it becomes part of a new integration in the installing account; see Install integration or download integration ZIP file.
