1. |
Can I change my Shopify connection after it is installed? |
The Shopify Integration App does not allow you to change the Shopify and/or NetSuite connection once it's installed. The reason is that we register order and product webhooks in your store during installation. If you change it, your integration will become corrupted. The ideal solution would be to install another copy of the integration to switch the Shopify connection. ImportantThe Replace Connection setting is intended for same-store scenarios only, for example, swapping to a secondary NetSuite connection for the same Shopify store. Do not use it to point to a different Shopify store, as this causes integration errors and unexpected behavior. If you want to sync a different Shopify store, uninstall the current store and reinstall using the new Shopify account. During installation, select Clone an existing Shopify store at the last step to carry over mappings and settings from your existing store. To uninstall the current store:
You will need to uninstall the “NetSuite connection status” and the “Shopify Store”. How this shows upAfter a connection is pointed at a different Shopify store or NetSuite account, the order flows fail in the integration app's pre-map hook with messages about the order data rather than about the connection, for example |
- Configure variant metafields using the NetSuite saved search
- Configure metafields using the “Specify your Shopify variant metafield components” setting
- Can I change my Shopify connection after it is installed?
- Would changing the concurrency speed up a data flow in the Shopify integration app?
- Mapping additional fields in Shopify - NetSuite Integration App
- Support custom visibility in the Shopify-NetSuite integration app
- Change Shopify store name in NetSuite and integrator.io
