Shopify is an e-commerce platform that allows users to set up an online store and sell their products. It helps you manage your orders – from inventory to the point of sale to shipping and returns.
Shopify documentation: API Guide , Authentication
Additional reference: Supported Shopify APIs
IMPORTANT: Select Set up new connectiononly when you want to create a new connection on the integration app that is already installed.
Follow the below instructions:
Name your connection (required) : Provide a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting a list of connections you’ve created.
Store name (read-only): integrator.io automatically fills the selected store. The store name that appears is based on the Shopify store user signed in.
Auth type (read-only): By default, OAuth 2.0 is selected.
Click Save & authorize . The Install integration: integration app name page appears. The Shopify Connection status appears as Configured.
The IO integration name dropdown displays the list of integration names, for easy identification of your integration, see the text in grey for the tag of the integration app tile. In the Connection field, after selecting the required connection, the default grey text in the connection name displays the store name as yourstorename. Once the connection is configured successfully, the actual Shopify store name is updated.
