Set up an HTTP connection to Shopify using a custom app
Effective January 1, 2026, Shopify no longer allows the creation of new legacy custom apps. As a result, new users cannot create a legacy custom app to retrieve an access token for configuring a Shopify connection using Token authentication in Celigo.
To configure Token authentication going forward, new users must create an app from the Shopify developer dashboard, obtain the required client credentials, and configure the authentication by following the steps described in this article.
  1. Sign in to your Celigo integrator.io account.
  2. Navigate to Resources > Connections > + Create connection > select Shopify.
  3. Switch to HTTP.
  4. Enter a connection Name.
  5. In the Configure authentication section, select and configure the authentication.
  6. From Auth type, select OAuth 2.0.
  7. In Configure OAuth 2.0, click + to create an iClient.
  8. Switch to HTTP.
  9. Enter a Name.
  10. Navigate to Configure OAuth 2.0 > Grant type.
  11. Select Client credentials.
  12. Enter the Client ID. How to retrieve the client ID.
  13. Enter the Client secret. How to retrieve the client secret.
  14. Click Save and close. You will be redirected to the Create connection HTTP page.
  15. Click Save and continue.
  1. Sign in to your Shopify developer account.
  2. Click Build apps in dev dashboard.
  3. Click Create app.
  4. In Start from dev dashboard, enter an App name.
  5. Click Create. The Version page appears.
  6. Enter your App URL. For detailed information, see Create apps using the dev dashboard.
  7. Select the Scopes.
  8. Click Release.
  9. From the left pane, navigate to Home > Install App.
  10. Select the Store and click Install.
  11. Navigate back to the Apps page. From the left pane, navigate to Settings.
  12. Copy the Client ID.
  13. Copy the Secret.
