Set up an OAuth 2.0 connection to Shopify
Shopify is an e-commerce platform that allows users to set up an online store and sell their products. It helps you manage your orders - from inventory to point of sale to shipping and returns.
To configure the Shopify connection in integrator.io, you must install the integrator.io app in the Shopify app store.
  • It is recommended to use the 2026-07 API version.
  • To set up an OAuth 2.0 connection to Shopify in Shopify - NetSuite integration app, see OAuth 2.0 connection in Shopify - NetSuite integration app.
  • If you are an EU user, please ensure you sign in with the EU Account sign in option to access the connection form. Attempting to log in through the global portal may redirect you back to the login page.
Setting
Instructions
Name your connection *
API type *
Choose your Shopify account API type:
  • HTTP: Use traditional HTTP methods (GET, POST, PUT, DELETE) for straightforward interactions with individual resources.
  • GraphQL: Use GraphQL for flexible, efficient queries and mutations, retrieving only the required data with a single endpoint.
API version
Select your Shopify account’s API version. For example, 2026-07. For more information, see REST admin API reference .
Store name * (Read-only)
The store name is automatically updated after you configure the OAuth 2.0 connection in the Shopify app store.
Auth type *
Select OAuth 2.0 as the authentication type for this connection. The form changes depending on the selected authentication type. The OAuth 2.0 authentication type requires configuring the connection from the Shopify app store.
This connector documentation describes only the settings shown for the Simple view.
For the corresponding:
Set up a new OAuth 2.0 connection from the Shopify app store
To configure the connection:
  1. Click Continue at the Shopify app store. The Celigo app page appears.
  2. Click Add app. The Login page appears.
  3. Sign in to your Shopify account. The Your stores window appears.
  4. Select the required store. The Install integrator.io page appears.
  5. Read the information and click Install app. The Celigo sign in page appears if the user is not signed in.
  6. Name your connection (required): Provide a clear and distinguishable name. Throughout integrator.io imports and exports, you can choose this new connection, and a unique identifier will prove helpful later when selecting a list of connections you’ve created.
  7. Provide the credentials and click Sign in. The Set up connection page appears.
  8. API version (required): Select your Shopify account’s API version. For example, 2026-01. For more information, see REST admin API reference.
  9. Store name (required): The form will automatically get the store name that was selected while configuring the app.
  10. Click Save & authorize. You will be navigated to the integrator.io > Connections dashboard page and you can see the connection Status as Online.
Use existing OAuth 2.0 connection from Shopify app store
  1. Navigate to the integrator.io app page.
  2. Click Open app. The Set up connection page appears.
  3. Choose Use existing connection.
  4. From Connection, select the required Shopify connection.
  5. Click Save & authorize. You will be navigated to the integrator.io > Connections dashboard page and you can see the connection Status as Online.
