Hootsuite is a popular social media management platform that allows users to schedule posts, engage with audiences, and analyze social media performance across multiple platforms from a single dashboard.
| Setting | Instructions |
| Name your connection * |
| API type * |
Choose your Hootsuite account API type:
| API type: Platform | |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Hootsuite. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource |
| API type: Inbox | |
Organization ID * |
Enter your Hootsuite organization ID. |
| Client ID * |
Enter your Hootsuiteclient ID. |
| Client secret * |
Enter your Hootsuite client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your client secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
| API type: Media library | |
| Valid domain names * |
Enter the unique domain name for the OAuth URL. Use comma-separated values to enter multiple URLs. For example, if your URL is
| Base URL * | Enter your Hootsuite account base URL. For example, if your Hootsuite account URL is https://xyz.hootsuite.com, then enter https://xyz.hootsuite.com. |
| API type: Sparkcentral | |
| Region * | Select your Hootsuite account region (either US or EU). |
| Scopes * |
Scopes are OAuth 2.0 permissions that Hootsuite defines to limit access to your account. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token and OAuth 2.0 universal connector documentation for the respective API types.
- Sign in to your Hootsuite developer portal.
- Navigate to My apps. For more information on how to create an app, see Authentication.
- Select the required app and click Edit.
- Copy the Client ID.
- Copy the Client secret.
- Navigate to My profile > Manage accounts and teams.
- Click your organization Teams.
- Copy the Organization ID in the id query parameter in your browser URL. For more information, see Retrieve the organization ID
