Celigo Ora overview
Celigo Ora is a natural language interface built into the Celigo platform that helps you create and update integration resources, investigate and resolve errors, and monitor your account through a conversational interface. Ora draws on context from your Celigo account, proposes changes as reviewable drafts, and applies them only after you explicitly approve.
Roles and permissions
Ora's available actions depend on your Celigo account role and permissions:
  • Monitor — Ora focuses on visibility and troubleshooting.
  • Manage — Ora can help you make configuration changes and run components you are authorized to run.
  • Admin or Owner — Ora can assist with broader administrative actions your account allows.
Ora does not have a separate permission set. It operates within whatever roles and scopes have been assigned to you at the account level and per integration.
Access Ora
To open Ora, select Ask Ora (AISparkle.svg) at the top right of the integrator.io screen.
Ora opens as a panel anchored beside the page. The page narrows to fit, so Ora doesn't cover your work. The panel stays open as you move between pages, and Ora's suggested prompts change to match the page you're on.
  • To resize the panel, drag the divider between the page and the panel. The panel can be up to about a third of the screen wide, and Ora keeps the width you set the next time it opens.
  • To move Ora over the page, select Detach Ora. Ora becomes a floating window that you can drag anywhere on the screen. To dock it again, select Anchor Ora.
  • To hide Ora, select Close. Ora stays closed, including after you reload the page, until you select Ask Ora again.
Ora reopens anchored or detached, whichever you used last.
To give Ora additional context, select + in the text area, then select Upload file or choose a file from Celigo File Storage. To speak your prompt instead of typing it, select +, then select Dictate.
Ora can read these file types:
  • Text and data files: CSV, TXT, JSON, XML, YAML, Markdown, log files, and EDI files (X12 and EDIFACT)
  • Excel workbooks (.xlsx), with every sheet read as a table
  • Word documents (.docx), including text and tables
  • PDFs
  • Images: PNG, JPG, GIF, and WebP, such as screenshots
You can attach up to 5 files in a message, and each file can be up to 5 MB. Ora doesn't read the older Word and Excel formats (.doc and .xls). Save the file as .docx, .xlsx, or CSV first.
Key concepts
The following sections define key terms you'll encounter when working with Ora, including how changes are staged, how Ora interprets your prompts, and what its domain capabilities cover.
Ora capabilities and use cases
Ora uses specialized domain capabilities, organized by resource type, to locate resources, stage reviewable changes, and retrieve audit history and dependencies. Ora can help you accomplish many common tasks in Celigo, including:
Resource management
  • Creating, updating, and organizing flows, exports, imports, connections, scripts and hooks, APIs, and others
Error management
Operational monitoring
  • Reviewing recent changes and audit history
  • Finding where a specific field, URL, or value is hardcoded across configurations
  • Improving mappings, filters, handlebars templates, and JavaScript used in hooks and transformations
Marketplace installs
  • Installing Ora-guided templates from the Marketplace
Ora is not the right tool when:
  • The outcome depends on business rules it doesn't have context for; for example, which system is the source of truth, or how to handle duplicate records
  • The underlying issue involves invalid credentials, unreachable endpoints, or data constraints outside Celigo's control
For prompt examples and specific use cases, see Celigo Ora use cases and prompts.
Staged changes
When Ora makes a change, it stages it as a draft in Celigo for your review. Nothing is applied until you explicitly approve it. You can ask Ora, "Show me exactly what will change" at any point to get a summary before approving.
A new flow, API, tool, or flow step that Ora creates is saved in your account right away as a draft. The draft is deleted automatically 48 hours after it was created unless you accept it.
To review a change, select Preview on its card in the conversation. To accept or reject it, use the list of pending actions at the bottom of the Ora panel. The list shows one entry for each resource, named with its type, and each entry has its own Accept and Reject. To act on every entry at once, select Accept all or Reject all in the bar that shows the number of actions. Only a deletion is confirmed on its own card, with Cancel and Confirm.
Accepting a draft makes it permanent. It doesn't turn a flow on. If a draft flow's approval was closed without accepting it, you can still keep the flow until it expires. Open the flow in Flow Builder, then select Accept all in the box at the top left of the canvas.
Changes Ora makes to a draft it created are applied to that draft directly, without a separate approval for each change. Changes to a resource that already exists in your account each get their own approval.
If a change doesn't save when you accept it
A change is saved only when its card reads Accepted. While its entry is still in the list of pending actions, nothing has changed.
If accepting a change doesn't save it, try these steps in order:
  1. Save or discard any unsaved edits in the form you have open.
  2. Reload the page in your browser.
  3. Reopen the conversation from the recent conversations list or Conversation history in the Ora panel. After a reload, the panel can open on its start screen or on a different conversation, and the list of pending actions belongs to the conversation.
  4. Accept the same entry again. If it still doesn't save, wait a few minutes and accept it once more.
If the card says the platform rejected the change and gives a reason, accepting again won't help. Tell Ora what the message says, and Ora corrects the change and stages a new one.
If accepting a change in the Ora panel doesn't save it, you can accept a pending change to an existing flow, flow step, or other resource on that resource's own page. Keep the conversation open in the Ora panel. The page shows a pending change only from the conversation it belongs to.
  1. Go to the page for the resource the change is for:
    • For a flow, go to Build > Flows and open the flow.
    • For a flow step, go to Build > Flows, open the flow, and select the step.
    • For any other resource, go to Resources > the resource type, such as Exports or Imports, and open the resource.
  2. Select Accept all. The page saves the whole change.
Warning: Don't select Accept all inside an editor, such as Edit mapping or Define input filter. Accept all there saves only that editor's part of the change, and the card still reads Accepted. The rest of the change isn't saved.
Ora execution modes
By default, Ora assumes you want it to execute an action; for example, create, update, or run a flow. If you say "how would you…" or "don't make changes yet," Ora switches to planning mode and explains what it will do without making any changes.
Performance tiers
Set your Ora performance tier at Account > Company info. The Priority tier provides faster, more consistent response times but costs more per interaction. The Standard tier provides normal response times, but a lower cost.
Chat history and session behavior
Each Ora chat session is independent. When you start a new chat, Ora has no memory of previous sessions.
When a conversation reaches Ora's context limit, Ora drops the earliest messages to make room for new ones, so details from the start of a long conversation may no longer be available. Ora can re-fetch live account and resource data through its tools, so it does not rely only on chat history. In a long session, restate any critical details or ask Ora to re-inspect a resource before making changes, or start a new conversation.
Select Conversation history (ClockCounterClockwise.svg) in Ora's header to view your conversation history. All conversations are available according to your data retention plan (calculated from each conversation's last used date), and you can continue querying Ora from any of them. You can rename, delete, or clear individual conversations.
Language support
Ora supports multiple languages, including Spanish, French, and Italian.
Feedback
To leave feedback on an Ora response, select Thumbs up or Thumbs down on each response in the Ora panel. In the explanation box, include:
  • What you were trying to do
  • What went well or didn't
  • The relevant resource or step name
  • Any error text so the team can reproduce the issue
If you are reporting a suggestion, describe the desired behavior and how it would improve your workflow.
Ora request processing
You tell Ora the outcome you want, and it uses context from your Celigo account to translate your intent into concrete, reviewable actions.
When you submit a prompt, Ora uses its domain capabilities to locate the relevant resources, propose changes as staged drafts, and summarize the impact before you approve anything.
For general how-to questions, Ora can consult up-to-date documentation. For troubleshooting, Ora analyzes error payloads and execution context to recommend fixes.
If Ora needs more information to proceed, it will ask a clarifying question in the chat rather than making an assumption. This might include questions about which system is the source of truth or whether you want to upsert vs. update.
Install an Ora-guided template
Ora-guided templates are Marketplace templates that Ora builds and configures for your account, using your answers and the connections you already have. They don't have a self-serve install wizard. Their tiles show an Ora badge.
To install an Ora-guided template, you need the Manage, Admin, or Owner role.
  1. Go to Marketplace Marketplace icon.
  2. Under By type, select Ora guided. To narrow the results to one kind of listing, also select a type, such as Templates.
  3. On the template's tile, select Install. Ora opens and sends a request to install that template.
  4. Answer Ora's questions. Ora reuses connections already in your account and prompts you to create any required connection that's missing.
  5. Review and approve the changes Ora stages.
Ora installs the template into your account, configured from your answers. After installation, the integration appears on your Home page as a new tile.
Note: To install an Ora-guided template, select Install on its tile, not on the preview page.
Ora guided shows every Ora-guided listing when selected alone. Selected with types, it shows only the Ora-guided listings of those types. For more about Marketplace filters, see Jump-start integrations with templates and apps.
Best practices and tips
Before you begin using Celigo Ora, check these best practices and tips:
Write clear prompts
  • State your intent upfront — Say whether you want a plan or execution. "Don't make changes yet" triggers planning mode; otherwise, Ora assumes execution and stages changes for approval.
  • Be specific and detailed — Include what you want Ora to do, how you want it executed, and in what order.
  • Be explicit about the target — Include the exact resource name and, when possible, the '_id' (flow, import, connection, integration). This prevents back-and-forth about which resource you mean.
  • When you say "this," include context — If you are not on the resource page, "this flow" or "this connection" can be ambiguous. Add the name or '_id'.
  • Provide environment details up front — For anything involving credentials or endpoints, specify production or sandbox, region (NA or EU), and which tenant or subdomain.
Scope changes safely
  • State the outcome and the guardrails — Example: "Update this flow to do X, but don't change schedules, mappings, or step order." Clear constraints help avoid unintended edits.
  • Give the time window and scope — For questions like "recent changes" or "errors," specify the last 24 hours, 7 days, or 60 days, and whether you mean one flow, one integration, or the whole account.
  • Expect drafts for anything that modifies configurations — Ask "Show me exactly what will change" if you want a summary before approving.
  • Break large changes into milestones — For complex, multi-step requests, ask Ora to proceed step-by-step with checkpoints so you can validate each stage before moving forward.
Safely modify production flows
If Ora modifies a production flow and the result isn't what you intended, there is no built-in way to revert the changes. Use the following approach to test changes safely before applying them to production:
  1. Clone the integration you want to modify.
  2. Go to the cloned integration's Admin, then turn on Allow Ora to apply changes automatically.
  3. Use Ora to make and test changes on the clone.
  4. Use Integration Lifecycle Management (ILM) to merge approved changes back to the original integration.
Error handling
  • Copy and paste errors verbatim — Include the full error message, any error code, and the step name. Small differences in error text often matter.
Context and credentials
  • Don't paste secrets — Enter tokens and passwords directly in the Celigo UI. Once you have done that, tell Ora "it's set in the UI" and Ora can proceed.
  • Add a file for additional context — A file you add in the text area gives Ora details it can't get from your account.
  • Update the page context — Each conversation uses the page that was open when you started it as context. If you move to another page and want Ora to use that page instead, type @current_page in your prompt.
  • Start a new conversation when the context changes — If a conversation runs long or you move on to different work, select New conversation.
Limitations
Ora can make mistakes. Always review changes before approving them.
  • Missing business rules — Ora cannot infer domain-specific decisions you haven't provided, such as which system is the source of truth, whether to create, update, or upsert, or how to handle duplicate records. When the outcome depends on a choice that materially changes behavior, Ora will ask for clarification rather than assume.
  • Unresolvable underlying issues — Ora can help diagnose and explain failures, but cannot guarantee a fix when the root cause involves invalid connections, unreachable endpoints, or data constraints outside Celigo's control.
  • No snapshot or rollback for configuration changes — Ora does not take a snapshot before modifying a resource, and there is no built-in rollback. Review all staged changes carefully before approving, and consider using the workaround described in the Safely modify production flows section when working with critical integrations.
  • Not available in legacy sandbox accounts — Ora is not available in legacy sandbox accounts. To use Ora in a non-production environment, see Migrate your sandbox environment to a non-production environment.
Usage credits
Ora is available for all users. Ora credits are one balance for your whole account. Every user and every environment draws from it, so when it runs out, Ora pauses in production and sandbox at the same time.
When credits run out
When the balance reaches zero, Ora pauses new replies and shows "You used all your Ora credits". Pending approval cards still work.
How credits refill
On paid plans, the balance is topped up automatically whenever it runs low. There's no daily or monthly reset, so a balance that only goes down is normal, and most accounts never run out. If your balance does run out, it refills on its own, usually within about 30 minutes. There is nothing to buy, request, or reset.
Trial accounts get a one-time allowance of Ora credits that doesn't refill. When it's used up, Ora stays paused until the account moves to a paid plan. Accounts whose plan has no Ora credits, such as an expired trial or the free tier, aren't refilled either.
If the message doesn't clear
Signing out, clearing your browser data, or switching browsers doesn't restore credits. After you wait, reload the page before you try again. On a paid plan, if Ora is still paused an hour after running out, the refill is overdue and only Celigo can restore it. Contact Celigo Support.
What uses credits faster
Every reply re-reads the whole conversation, so a reply deep in a long conversation costs many times what the same reply costs in a new one. A long build-and-debug session in a single conversation can use up a refill in an hour or two. Start a new conversation for each new task. The Ora performance tier setting (see Performance tiers) also affects cost: Priority costs about twice as much per reply as Standard.
Where to see your balance
The Subscription page doesn't show your Ora balance. Its AI credits remaining figure is a separate balance for AI agents and guardrails. To check your remaining Ora balance, an account owner or administrator can ask Ora.
Access, agency, and security
Ora does not learn from your conversations, and Celigo's data protection policies apply to Ora. All activity is fully contained within your account, and Ora can only perform actions that you are authorized to perform.
Any changes Ora executes are recorded through Celigo's audit logs, the same way changes are recorded when you do them directly in the UI. Audit logs capture who made the change, when it happened, what was changed (including old/new values), and the source of the change (for example, UI vs Ora vs API vs System/Stack, depending on the action). Sensitive data (like a password/token) isn't exposed in the audit trail, and you can filter and export audit log data when you need to review history or support an internal change-control process.
Related articles
