Salesforce Bulk API 2.0 Guide
To create a Salesforce export, see Export data from Salesforce. While creating an export, select Bulk API 2.0. It manages high-volume data from Salesforce.
When you create or update Salesforce export to Bulk API 2.0, note that Bulk API 2.0 does not support the below:
  • Compound fields in SOQL queries. Ensure to query the individual components of compound fields. Example: Address Compound Fields, Geolocation Compound Fields.
  • Attribute fields. Use REST API to use attribute fields.
  • Aggregate functions. Example: Sum(), Count(), ALL(), queries with GROUP BY, LIMIT, ORDER BY, OFFSET, or TYPEOF clauses.
  • Parent-to-child relationship queries are not supported. However, child-to-parent relationship queries are supported.
  • Attachments and Blob fields
  • There are certain data type differences in Bulk API 2.0 compared to REST API that might affect import mapping.
    API type
    REST
    Bulk API 2.0
    Currency
    100
    100.0
    datetime
    2024-04-16T19:00:00.000+0000
    2024-04-16T19:00:00.000Z
    Percent
    10
    10.0
    Number
    23
    "23.0"
    Roll-Up Summary
    0
    "0.0"
    Empty field values
    null
User experience differences
  • The Salesforce connector in Bulk API 2.0 does not support preview.
  • To add fields (using dropdown values) to the import or lookup criteria/mappings, you should either populate mock output data in the export or initially map the fields using the REST API and then update the export to Bulk API 2.0.
