If your account is on EM 2.0, you can view the Salesforce HTTP request and response errors provided that both requests and responses result in an error and the Source is Application.
Importing data into Salesforce
SOAP
REST
Composite
Extract data from Salesforce
Scheduled flow with SOQL export
Real-time flow via Listener
The request and response errors integrator.io displays are determined by the flow steps.
If you make an export or (dynamic) lookup request that results in an error, you can view the request and response in two separate panels in the Actions menu in the flow run dashboard. The error details will vary depending on where the export or lookup failed. Note that both the request and response must have errors.
Protocol |
Sample error details |
SOQL REQUEST |
{ "method": "GET", "uri": "https://diksha-khatri-15-dev-ed.my. salesforce.com/services/data/v40.0/query/?q=SELECT%20Id%2C%20Name%2C%20ProductCode%2C%20Description%20FROM%20product2%20WHERE% 20ProductCode%20!%3D%20''%20limit%201", "headers": { "Authorization": "********" }, "maxResponseBytes": 26214400 } |
SOQL RESPONSE |
{ "headers": { "date": "Thu, 22 Jul 2021 06:39:20 GMT", "set-cookie": [ "CookieConsentPolicy=0:0; domain=diksha-khatri-15-dev-ed.my.salesforce.com; path=/; expires=Fri, 22-Jul-2022 06:39:20 GMT; Max-Age=31536000", "BrowserId=izjEHeq3EeuyYcF_M7mnsQ; domain=.salesforce.com; path=/; expires=Fri, 22-Jul-2022 06:39:20 GMT; Max-Age=31536000" ], "strict-transport-security": "max-age=31536000; includeSubDomains", "x-content-type-options": "nosniff", "x-xss-protection": "1; mode=block", "x-robots-tag": "none", "cache-control": "no-cache,must-revalidate,max-age=0,no-store,private", "sforce-limit-info": "api-usage=52/15000", "content-type": "application/json;charset=UTF-8", "vary": "Accept-Encoding", "transfer-encoding": "chunked", "connection": "close" }, "body": "{\"totalSize\":1,\"done\":true,\"records\":[{\"attributes\": {\"type\":\"Product2\",\"url\": \"/services/data/v40.0/sobjects/Product2/01t2v000009MIEaAAO\"}, \"Id\":\"01t2v000009MIEaAAO\",\"Name\":\"GenWatt Diesel 200kW\",\"ProductCode\":\"GC1040\", \"Description\":null}]}" } NoteResponse → Other sections will have at least these 2 fields: { "statusCode": XYZ, "receivedAt": 1626873055700 } |
If you make an import request that results in an error, you can view the request and response in two separate panels in the Actions menu. The error details will vary depending on where the import failed. Note that both the request and response must have errors.
Protocol |
SOAP REQUEST |
{ "uri": { "protocol": "https:", "slashes": true, "auth": null, "host": "diksha-khatri-15-dev-ed.my.salesforce.com", "port": null, "hostname": "diksha-khatri-15-dev-ed.my.salesforce.com", "hash": null, "search": null, "query": null, "pathname": "/services/Soap/u/40.0/00D2v0000012nV4", "path": "/services/Soap/u/40.0/00D2v0000012nV4", "href": "https://diksha-khatri-15-dev-ed.my. salesforce.com/services/Soap/u/40.0/00D2v0000012nV4" }, "method": "POST", "headers": { "User-Agent": "node-soap/0.24.0", "Accept": "text/html,application/xhtml+ xml,application/xml,text/xml;q=0.9,*/*;q=0.8", "Accept-Encoding": "none", "Accept-Charset": "utf-8", "Connection": "close", "Host": "diksha-khatri-15-dev-ed.my.salesforce.com", "Content-Length": 877, "Content-Type": "text/xml; charset=utf-8", "SOAPAction": "\"\"" }, "followAllRedirects": true, "body": " <!--?xml version=\"1.0\" encoding=\"utf-8\"?--> <soap:Envelope xmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:fns=\"urn:fault.partner.soap.sforce.com\" xmlns:tns=\"urn:partner.soap.sforce.com\" xmlns:ens=\"urn:sobject.partner.soap.sforce.com\"><soap:Header><urn:SessionHeader xmlns:urn=\"urn:partner.soap.sforce.com\">\n <urn:sessionId >00D2v0000012nV4!AQQAQF5iIJ6YEGc_ XYU8tlZ2DmPGKAFxOJbGHgm81Lgztp0f LFHIWGJtK8_eYfUYOl0E78uTdMjzaRrzRiJNkB1CMl7MNYW3 </urn:sessionId>\n </urn:SessionHeader>\n<urn:CallOptions xmlns:urn=\"urn:partner.soap.sforce.com\">\n <urn:client>Celigo/IntegratorDistributedAdaptor/ </urn:client>\ n</urn:CallOptions ></soap:Header><soap:Body> <create xmlns=\"urn:partner.soap.sforce.com\" ><sObjects> <ens:type xmlns:ens=\"urn:sobject.partner.soap.sforce.com\">Product2 </ens:type></sObjects> </create></soap:Body></soap:Envelope>", "maxResponseBytes": 5242880 } |
SOAP RESPONSE |
{ "headers": { "date": "Wed, 21 Jul 2021 16:40:52 GMT", "set-cookie": [ "CookieConsentPolicy=0:0; domain=diksha-khatri-15-dev-ed.my.salesforce.com; path=/; expires=Thu, 21-Jul-2022 16:40:52 GMT; Max-Age=31536000", "BrowserId=aYFhkOpCEeuy_kOVu5OQKA; domain=.salesforce.com; path=/; expires=Thu, 21-Jul-2022 16:40:52 GMT; Max-Age=31536000" ], "cache-control": "no-cache,must-revalidate,max-age=0,no-store,private", "content-type": "text/xml; charset=utf-8", "vary": "Accept-Encoding", "transfer-encoding": "chunked", "connection": "close" }, "body": " <!--?xml version=\"1.0\" encoding=\"UTF-8\"?--> <soapenv:Envelope xmlns:soapenv=\ "http://schemas.xmlsoap.org/soap/envelope/\" xmlns=\"urn:partner.soap.sforce.com\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"> <soapenv:Header> <LimitInfoHeader><limitInfo><current>8 </current><limit>15000</limit><type>API REQUESTS </type></limitInfo></LimitInfoHeader> </soapenv:Header><soapenv:Body><createResponse> <result><errors><fields>Name</fields> <message>Required fields are missing: [Name]</message><statusCode>REQUIRED_FIELD_MISSING </statusCode></errors> <id xsi:nil=\"true\"/> <success>false</success></result></createResponse> </soapenv:Body></soapenv:Envelope>" } NoteResponse -> Others section will have at least these 2 fields: { "statusCode": XYZ, "receivedAt": 1626873055700 } |
Protocol |
REST REQUEST |
{ "relativeURI": "/services/data/v40.0/sobjects/Product2", "uri": "https://diksha-khatri-15-dev-ed.my.salesforce.com/services/data/v40.0/sobjects/Product2", "headers": { "Accept": "application/json", "Content-Type": "application/json", "Authorization": "Bearer ********" }, "method": "POST", "json": { "id": "38", "Internal Id": "38", "SKU": "PRI00002", "Quantity": "19" }, "followAllRedirects": true } |
REST RESPONSE |
{ "body": [ { "message": "No such column 'Internal Id' on sobject of type Product2", "errorCode": "INVALID_FIELD" } ] } |
Protocol |
COMPOSITE REQUEST [similar to REST REQUEST] |
{ "relativeURI": "/services/data/v43.0/composite", "uri": "https://diksha-khatri-15-dev-ed.my.salesforce.com/services/data/v43.0/composite", "headers": { "Accept": "application/json", "Content-Type": "application/json", "Authorization": "Bearer ********" }, "method": "POST", "json": { "allOrNone": true, "compositeRequest": [ { "body": { "allOrNone": true, "records": [ { "attributes": { "type": "Product2" }, "Id": "38", "ProductCode": "1234" } ] }, "method": "PATCH", "referenceId": "refProduct2", "url": "/services/data/v43.0/composite/sobjects" } ] }, "followAllRedirects": true } |
COMPOSITE RESPONSE [similar to REST RESPONSE] |
{ "body": { "compositeResponse": [ { "body": [ { "success": false, "errors": [ { "statusCode": "MALFORMED_ID", "message": "Product ID: id value of incorrect type: 38", "fields": [ "Id" ] } ] } ], "httpHeaders": {}, "httpStatusCode": 200, "referenceId": "refProduct2" } ] } } |
Protocol |
BLOB export request |
{ "method": "GET", "uri": "https://d2e000000p4lxuaa-dev-ed.my.salesforce.com/services/data/v52.0/sobjects /Document/0152E0000032bRTQAY123", "headers": { "Authorization": "Bearer *********" } } |
Blob export response |
[ { "errorCode": "NOT_FOUND", "message": "Provided external ID field does not exist or is not accessible: 0152E0000032bRTQAY123" } ] |
Blob import request |
{ "uri": { "protocol": "https:", "slashes": true, "auth": null, "host": "d2e000000p4lxuaa-dev-ed.my.salesforce.com", "port": 443, "hostname": "d2e000000p4lxuaa-dev-ed.my.salesforce.com", "hash": null, "search": null, "query": null, "pathname": "/services/data/v52.0/sobjects/attachment/00P2E00001vlA6vUAE", "path": "/services/data/v52.0/sobjects/attachment/00P2E00001vlA6vUAE", "href": "https://d2e000000p4lxuaa-dev-ed.my.salesforce.com/services/data/v52.0/sobjects/attachment/00P2E00001vlA6vUAE" }, "method": "PATCH", "headers": { "Content-Type": "multipart/form-data;boundary=boundary_string", "Authorization": "Bearer ****************", "host": "d2e000000p4lxuaa-dev-ed.my.salesforce.com" } } |
Blob import response |
[ { "message": "Unable to create/update fields: ParentId. Please check the security settings of this field and verify that it is read/write for your profile or permission set.", "errorCode": "INVALID_FIELD_FOR_INSERT_UPDATE", "fields": [ "ParentId" ] } ] |
