Set up a connection to Zendesk
Zendesk is a customer service platform that enables businesses to manage and resolve customer inquiries efficiently through multiple channels, including email, chat, and social media.
After you start the connection, configure it in the Create connection panel and complete all the required * authentication settings:
Setting
Instructions
Name your connection *
API type *
Select your Zendesk API type:
  • Zendesk Support: Get tickets, users, organizations, custom objects, and manage ticket workflows.
  • Zendesk Sell: Get sell-powered applications for the web, mobile, and desktop.
API type: Zendesk Support
Subdomain *
Enter your Zendesk Support subdomain. For example, if your Zendesk Support account URL is https://hugesuccess.zendesk.com, then hugesuccess is the subdomain.
Auth type *
Select your Zendesk Support account authentication type (either Custom, OAuth 2.0, or Token).
Username *  (only for Custom auth type)
Enter your Zendesk Support account email address.
API token * (only for Custom auth type)
Enter your Zendesk Support API token.
dataLoad.svg​​ How to retrieve the API token
Grant type * (only for OAuth 2.0 auth type)
Select your OAuth 2.0 grant type (either Authorization code, Authorization code with PKCE, or Client credentials).
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Zendesk.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( pencil.svg ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Access token * (only for Token auth type)
Enter your Zendesk Support access token.
dataLoad.svg​​ How to retrieve the access token
API type: Zendesk Sell
OAuth 2.0 client *
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit ( pencil.svg ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom, OAuth 2.0, and token auth respective universal connector documentation.
How to retrieve the client ID and client secret (Zendesk Support)
  1. Sign in to your Zendesk account.
  2. Navigate to Apps and integrations > APIs > OAuth clients.
  3. Click Add OAuth client.
  4. Enter the required details.
  5. Paste the Callback URL in the Redirect URL field.
  6. Copy the Identifier (Client ID).
  7. Click Save.
    Once the page refreshes, a new Secret field will automatically appear at the bottom of the page. This field contains the client_secret value, as defined in the OAuth 2.0 spec.
  8. Copy the Client secret.
How to retrieve the client ID and client secret (Zendesk Sell)
  2. Navigate to Settings > Preferences > OAuth > Developer apps.
  3. Click+ Add developer app.
  4. Paste the Callback URL in the Redirect URL field.
  5. Click Save.
  6. Copy the Client ID.
  7. Copy the Client secret.
  • Sign in to your Zendesk account.
  • Click on Apps and integrations.
  • Navigate to APIs > Zendesk APIs.
  • Click on the Settings tab and ensure that Token access is enabled.
  • Click on Add API token.
  • Add an API description.
  • Copy the API token.
  • Navigate to OAuth clients > Add OAuth client.
  • Add the required details in the fields.
  • Click Save.
  • Copy the Secret (access token).
Additional references
