The Snowflake data warehouse platform offers a cutting-edge solution for modern data management, tailored to meet the needs of today's data-driven organizations. It seamlessly integrates with the cloud, providing unparalleled flexibility, scalability, and performance. The Snowflake architecture allows you to effortlessly store, process, and analyze vast amounts of data from diverse sources, ensuring real-time insights and actionable intelligence. For more information, see Key Concepts & Architecture.
For information on data types supported by Snowflake's platform, see Data Types. Make sure that your account has the necessary access control for the export and import options you select.
The Celigo platform has achieved the following Snowflake-issued certifications.
This connector is certified under the Snowflake Ready technology validation program, which optimizes Celigo integrations with Snowflake, emphasizing functional and performance best practices
Celigo is in the Select tier of AI Data Cloud Products - Connected Applications
Start establishing a connection in one of the following ways:
From the top right of the Home screen, click + Create, and then click Connection.
– or –
From within Flow builder, click Add source or Add destination / lookup.
From the General section of the flow step, click Create connection.
- or -
Click Resources in the left navigation menu, click Connections > Create connection.
In the resulting Application list, click Snowflake.
The General section of the Create connection pane then asks you to name the new connection.
For information on Snowflake's access control framework, see Overview of Access Control.
At this point, you’re presented with a series of options for modifying the Snowflake authentication.
Account name (required): Enter the Account name for this account set up by the Snowflake server administrator. For example, celigo_partner is the account name, which can be obtained from the URL.
Default database name (required): Enter the Snowflake database that you want to connect. For example, TEST_DB is available in the list, but you can also create a new one by clicking Create.
You can enter a default database name here, then override the default database and schema or specify a table in your export or import.
Warehouse name (required): Enter the Warehouse used for executing the compute process. For example, QA_WAREHOUSE is available in the list, but you can click Create to create a new warehouse. If you are using this connection for the Snowflake Data Warehouse quickstart integration template , verify that the Snowflake warehouse you select has Auto Resume set to Yes.
Authentication type: Use key pair authentication.
Snowflake has announced that single-factor password authentication will soon be deprecated. Snowflake will block single-factor authentication using only a username and password. For details and the latest roll-out plans, see Planning for the deprecation of single-factor password sign-ins
If you have any existing Snowflake connections that use Basic or single factor authentication, then to ensure uninterrupted access and enhanced security, update your connections to use key pair authentication.
See how to migrate to key pair authentication to update your connections.
Key pair: This authentication method requires, as a minimum, a 2048-bit RSA key pair. The key must be in the PEM format. You must include the prefix "-----BEGIN ENCRYPTED PRIVATE KEY-----" and the suffix "-----END ENCRYPTED PRIVATE KEY-----" when entering the key. See Snowflake documentation for more information on private keys.
Username (required): Enter the Username to connect to Snowflake. For example, DEV_QA.
Private key (required): Use this field to store the encrypted or unencrypted RSA private key used for authentication. The key must be in PEM format, and you must include the prefix "-----BEGIN ENCRYPTED PRIVATE KEY-----" and the suffix "-----END ENCRYPTED PRIVATE KEY-----". See Snowflake documentation for more information on private keys.
Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Private key passphrase (optional): Provide an optional passphrase. This is used to decrypt the Key field. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Default schema (optional): Name of the schema that the connection will use. If the name is not provided, the connection will use the default schema defined in Snowflake for the user.
You can specify your default schema here, then override the default or use a specific schema in an export or import.
User Role (optional): Name of the roles to use in the connection. If the user role is not provided, the connection will use the default user role defined in Snowflake for the user.
Password (required): Enter the password to connect to Snowflake.
Once you have configured the Snowflake connection, select one of the following options:
Save: Click this button to save the connection.
Close: Click this button to exit the Create connection panel without saving your changes.
