Regular expressions (regex) allow you to find patterns in text strings. Regular expressions have a unique syntax that uses special characters to represent the patterns you want to find, and a variety of resources are available online if you want to familiarize yourself with how regular expressions work.
For information on using regex with Cash Application Manager (CAM), see Regular Expression with Capture Groups to extract specific information from bank file and Regular Expressions Support for BofA Wires, SVB, Wells Fargo, HSBC Wires and PNC Wires.
You can use regex to find, replace, prefix, or append instances of text patterns you define. The most common regex use cases for integrator.io wrap the regular expression in a handlebars format to allow the system to recognize that the pattern expressed should be parsed with a regex engine. When building a regular expression, you should first use a regex tester to verify your regular expression matches the patterns you want to capture. You can then use your regular expression with one of the following handlebars expressions to perform the operation within the context of a flow:
regexMatch: Use this to match the input data based on the regular expression and return the data based on index and options variables.
regexReplace: Use this to return a modified string where the pattern has been replaced.
regexSearch: Use this to search for a match, and return the position of the result in the dataset, where 0=first position and 2=third position.
The Celigo platform uses the Node.js internal regular expression (regex) engine. See the following resources on Mozilla's developer website for information on supported regex functionality:
JavaScript string objects:
regexMatch, regexReplace, and regexSearch handlebars expressions require you to enter the following parameters:
field: the field name containing the variable or values to be matched, replaced, or searched. You can reference a field or variable by typing its name without double quotes (or curly braces or parens).
regex: the new value which will match, replace, or search the existing value.
index: the position of the result in the dataset, where 0=first position and 2=third position.
options: modifies the search flag of the expression. For example, regular expressions stop at the first match in the text content by default. The "g" flag indicates that the regular expression should be tested against all possible matches in a string. See Advanced searching with flags.
The index parameter is not used in regexSearch.
The following handlebars expression uses regexReplace to remove formatting to ten digit phone number fields.
"phone" : "(999) 888-7777"
This expression removes the parens from the first three digits, removes the following space character, and removes the hyphen after the next three digits yielding 9998887777
{{regexMatch (regexReplace phone "" "[^\d]" "g") "\d{10}$" "g"}}
The following handlebars expression uses regexMatch to extract the value contained between two parentheses. For example, if your field has a value that is formatted as follows:
"exampleField": "(BR12345)-WIT-1"
Use the following regexMatch expression to return only the value within the parentheses:
{{regexMatch exampleField "(?<=\()(.*?)(?=\))" "g"}}
This example returns the following:
BR12345
